Question about Acer Aspire 5002WLMi Notebook
Acer Aspire 5002WLMi Laptop won't recognize full 320 Gigabytes of new PATA hard drive. It's always been running a 80 Gigabyte 4200 RPM but that drive is old...a 2005 HD. New WD320 only reads 137 Gigabytes...but, runs very nice and fast...5200 RPM.
  • Anonymous Nov 05, 2011
    Yea - I tried all the Microsoft Register settings, Acer has no new BIOS to flash, Linux wouldn't even read the drive past 137 gigs. I thought about using the 320 HD in a USB case but, it is a PATA (old) and all the cases I find are SATA/SATA2/SATA3. What I decided to do is keep the hard drive installed instead of returning it for a 120 gig and use it partitioned in a 50 gig for drive c: and 75 gig for a extended drive under XP Pro sp3 install. Acer tells me that there is no changing my 48bit motherboard to anything better than it is short of buying a new motherboard then I may as well buy a new laptop. With 2gigs RAM and this new 125 gig setup it runs stable and fast without reaching the FAT (NTFS) file edge making it unstable so I'll just leave it like this for another 5 years. Thanks for your suggestion.
Chris Hingee
  • Acer Master
  • 32,281 Answers
The BIOS in the ACER determines the maximum size of the hard drive it can support.
Check the laptop's specification to see the max size you can install in this model laptop.
It appears that the max size your laptop can support is 140 Gb (unformatted). 137Gb formatted.
I suggest you install a hard drive up to 140 Gb capacity in your laptop and place the 320 Gb hard drive in an USB hard drive adapter case and when you attach this hard drive to the USB port in your ACER laptop then you will be able to get the full 320 Gb capacity after you delete the partition and create a 320 Gb partition and format the hard drive.
Posted on Nov 03, 2011
1helpful
Can i put a hdd from a aspire 5610 in to a5580
1) Acer Aspire 5610 series Notebook PC, uses a standard sized
SATA laptop harddrive.
http://www.ebay.com/itm/Acer-Aspire-5610-SATA-Hard-Drive-Caddy-w-Screws-/380170405559
[ Standard size laptop harddrive; 2.5 inches across in width. ( 2 and a half inches, or 63.5mm ]
2) Acer Aspire 5580 uses an IDE (PATA) harddrive, that is standard laptop size.
http://www.upgradecomputermemory.com/ram.cfm//memory/a/Acer/AcerAspire-Notebook-Series/Aspire5580Notebook/80GB-Notebook-Hard-Drive-for-the-Acer-Aspire-5580-Notebook.html
[ Scroll down to the subheading - Interface: ATA-100 ]
It isn't just the harddrive caddy that is different.
The two technologies are different, IDE (PATA) and SATA, therefore the interface is also.
[ Interface:
In this example I am referring to the pin connector, the harddrive plugs into ]
Parallel ATA,
http://en.wikipedia.org/wiki/Parallel_ATA#IDE_and_ATA-1
Serial ATA,
http://en.wikipedia.org/wiki/Serial_ATA
Adapter for the SATA harddrive (5610) to the IDE (PATA ) interface in the 5580 laptop?
Won't work.
1) The technologies are different.
2) There is a Chipset, or more than one, for this bus controller. The 5580 doesn't have a SATA version.
( Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit )
This would make one think, "Hey, I'll just buy an IDE (PATA) 2.5 harddrive."
Nope.
Once Windows Vista is installed it is a 'Bear' to write XP over it.
There is a Correct procedure. This is left to an experienced person.
(Even an experienced tech may have problems)
Also, IF you do get XP to write over Vista, you may be required to Activate again. (Not register, activate)
To explain further;
When Windows is installed on a computer, hash values are assigned to certain major hardware components.
Some examples may be the Processor, Motherboard, Harddrive, and graphics chipset.
More specifically for the Motherboard, it is the motherboard chipset, and the BIOS program. (Version and date)
Change any two of these hardware components, and Windows may want to be activated again.
Suggest new IDE (PATA) harddrive for the 5580, and use the Restoration Disk.
Don't have one?
Computer manufacturers stopped including a Restoration CD Disk.
(I do believe they have started again, though)
Many users felt uncomfortable trying to repair their computer, took it to a shop, and never bothered using the disk.
Many lost the disk.
Let's say the disk cost around $1.
Take that times 50,000 computers or so. The computer manufacturer is saving money, not including a disk the majority, seems to not want to use.
The computer manufacturers started including a restoration partition, on the harddrive. (That's nice unless you have graphics problems, and can't see what is going on)
When the computer is new, and the owner starts the computer for the first time, there is a pop up asking if you wish to make a Backup.
THIS, is your Restoration Disk.
The new owner is ONLY asked ONE time. If the owner clicks on 'Never show this again', the opportunity is GONE.
What to do?
New IDE (PATA) harddrive, see what it costs a shop to put Vista (Same version) on it.
OR,
Buy a new Vista, or Windows 7 genuine copy, and install it.
HOWEVER, before trying to install Win7, make SURE there are drivers for Win7 available.
If not, DO NOT install Win7.
(Microsoft makes ONE master disk of an Operating System.
{ And version } From it all GENUINE copies are made, and sold to the consumer )
Summary:
1) New IDE (PATA) harddrive
2) Have Vista installed, or see if drivers are available, and install Win7.
For clarification on anything I have stated, or additional questions, please post in a Comment.
Regards,
joecoolvette
Is the 'DVD-Super Multi DL Drive' on the Acer 5742 Aspire basically a DVD rewriter, or does it just play DVD's?
This Super-Multi Drive will write to dual layer DVDs (DVD+R DL or DVD-R DL) at a 4x speed. The full specs of the Acer 5742 are available here: http://support.acer.com/acerpanam/notebook/2010/Acer/Aspire/Aspire5742/Aspire5742sp2.shtml .
You should be able to place a dual layer dvd in the drive and have it recognized. Windows may ask you if you want to format the disc.
I hope this helps.
I have a Acer laptop 5000 series, Model.ZL5. It has a 80GB hard drive fitted. Is there a limit to how big a hard drive i can upgrade to?
This laptop supports Parallel connection for hard drive. Most PATA or Parallel ATA hard drives can only support up to 320Gb. There are some PATA hard drives up to 500gb. To answer your question, there is no problem on how huge the size of the hard drive. Just make sure you get a PATA hard drive. :)
~jash
3answers
Can you let me know what is the maximum installable HDD capacity 0f Lenovo laptop 3000 C100.Can i upgrade present capcity of 40GB to 320GB ?
If you have windows xp with service pack 3, there is no limit. There is no limit if you run Vistaor Windows 7. If you don't have service pack 3, you are limited to 137 gb.
1helpful
2answers
Need to replace acer aspire 5314 hard drive. Where can I find one?
You need a 2.5" 150 Gigabyte drive; however, those laptops are prone to a short in the serial connection from the motherboard. This is an almost impossible task for an novice user to change a motherboard and the cost is not worth it. I installed a new hard drive and although the laptop recognized it, it still will not recognize it and load the operating system. Tested drive on another laptop and it works flawless. The hard drive became bad from the short which you can sometimes hit the bottom of the unit and make it work long enough to backup the data.
2helpful
2answers
I need to replace the hard drive in my v5000 Compaq laptop. it is currently a mk8025gas toshiba 80gb. how do i choose a newer updated hard drive to match? do i just install and turn back on with the xp...
Basically you insert a new drive and insert the Windows XP installation CD and follow the screen instructions.
The specification for hard drives for the Compaq V5000 are as follows :-
Table 6-3
Hard Drives
120-GB* 100-GB* 80-GB*
Dimensions
Height
Width
Weight
9.5 mm
70 mm
102 g
9.5 mm
70 mm
102 g
9.5 mm
70 mm
99 g
Interface type ATA-5 ATA-5 ATA-5
Transfer rate
Synchronous (maximum)
Security
100 MB/sec
ATA security
100 MB/sec
ATA security
100 MB/sec
ATA security
2answers
Installing new Acer Aspire 3200LCi Hard drive
try the jumpers set its th masterand slave thing
Hard drive
You will need any 2.5" inch hard drive. The size that you choose is your option.
However, I do recommend at least 60-80 gigabytes minimum for any operating system these days.
You will want to be sure that you are not buying a SERIAL ATA drive as this particular model still uses the standard IDE interface hard drives.
Also note that there are different speeds of hard drives. For laptops, the usual speeds are 4200 RPM and 5400 RPM. In order to gain the best performance, you will want to find a hard drive with the 5400 RPM speed.
I have taken the liberty of looking up a couple good hard drives on newegg.com. (The best site for buying PC parts...as well as many other things.)
The following link is what I consider to be a pretty good deal. Good size at 160GB and is 5400 RPM.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148224
The next link is more for economy if you don't want to spend that much money. It is an 80GB drive with the better 5400 RPM speed for performance. This is the lowest I would go whether your a hardcore user or even a casual user. Great price for this drive. :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148128
If you have any further questions, please come back and ask them. I would rather continue helping you to find a solution than to receive a lower rating.
I'll be watching. :)
Cyryl
Open Questions:
Acer Aspire 5002WLMi Notebook Logo
Ekse
Steve Sweetleaf
Steve Sweetleaf
Michael Thomas
Michael Thomas
