Question about Frymaster Dean SR42G Deep Fryer
For a frymaster sr42where can i get a pilot assembley
Posted by chris pugh on
Susan Bennett
    Scholar:
    New Friend:
  • 99 Answers
We can order parts for your fryer, but do you have a serial number too?
It's alot easier to order correct parts with the model and serial number.
I realize that sometimes the serial is burnt off, so if that's the case, never mind...Let me know and we can price you one and ship it directly to you.
Thanks,
Susan
Restaurant Equipment Outlet
Cincinnati, OH
Posted on Jan 04, 2012
How to change the pilot light thermocouple on my frymaster
the bottom cover may reveal it. It may need the shell removed. Look for tine screw to remove to release it.
Jan 19, 2017 | Frymaster Kitchen Appliances - Others
Frymaster
Turn gas valve to off for 5 minutes, then turn to pilot and push in and hold then light pilot light, release slowly and turn to on.
Apr 23, 2013 | Frymaster Kitchen Appliances - Others
I am not able to get the pilot light lit on my frymaster gas fryer. I have had this issue before in the past two months and it was a clogged gas orphus. Were is the gas orphus located so that i can take it...
All Manuals are available on Frymasters website. the orifice is located in the pilot line where the gas line connects to the pilot. You will have to unscrew the fitting and remove the orifice. It is best to clean the entire pilot assembly and the gas line going to the orifice. Many times when a pilot tube has leaked and possibly burned incorrectly, the gas line can fill up with suit. Your clogged orifice could recur if the line is not cleaned as well. I have had to return to customers locations only to find an orifice I cleaned was clogged again. I then removed the pilot feed line, when I blew through is it filled my hand with black suit. It can be a messy and frustrating job to pull all this apart. You may want a professional. Be sure you have no gas leaks upon completion, use soap bubbles to check for leaks! Click here to download manual from frymaster
Jul 11, 2010 | Frymaster Dean Frymaster/Dean HD50G Deep...
Piot light will go out
its likley to be the thermal cut out playing up its not holding the gas on as its getting week a new one will sort this problem out first time
Nov 12, 2009 | Frymaster Dean GF14 Deep Fryer
I need to know how to lite the pilot on my frymaster fryer
fry099_16_4.gifMake sure the thermostat is turned off. Units burners will light as soon a pilot in it is on. fry099_16_5.gif 3-2 Lighting the Pilot and Burner Figure 1 Figure 2 3. Push the knob in and light the pilot. Continue to hold the knob in for about 60 seconds after the flame appears on the pilot. Release the knob. The pilot should remain lit.
I suggest that you boil it out before using. This cleans the pot of any contaminants here is how to do this.
Boiling Out the frypot To ensure that the frypot is free of any contamination resulting from its manufacture, shipping, and handling during installation, the frypot must be boiled out before first use. Frymaster recommends boiling out the frypot each time the oil or shortening is changed. 1. Before lighting the burner, close the frypot drain valve and fill the frypot with a mixture of cold water and boil-out solution or detergent. Fill to the lower oil-level line. 2. Light the fryer in accordance with the lighting instructions in Section 3.1. 3. Simmer the solution for one hour.
I would attempt to paste the complete owners manual but it's just way to large. I do warranty for Frymaster is how I have access to it. Good luck
Oct 17, 2009 | Frymaster Dean GF14 Deep Fryer
Can light pilot, but when I release to turn it on, pilot goes out
Make sure that the pilot flame is making direct contact with the thermocouple. You may want to try to use a lighter to provide direct heat to the thermocouple and when you push the pilot reset button you should be able to feel it grab when releasing the button(it may take a minute or two). If the ASO still does not hold after applying direct heat to the thermocouple and you have good pilot/thermocouple impingment it could be the thermocouple. Usually fryers of this type use a standard thermocouple but some systems involve a pilot generator. If it is not the thermocouple it can then be a bad mag head(not very common) and will require a new gas control assembly from frymaster.
Sep 04, 2009 | Frymaster Dean Kitchen Appliances - Others
I have a frymaster model mj35ssp cannot find where to light the pilot light at! Can someone please tell me
If you forward your e-mail address I will send you the Frymaster instructions w/ picture of where to light the pilot.
Rick
[email protected]
Jul 21, 2009 | Frymaster Dean MJ35-SC-1 ''Standard'' Deep...
Frymaster Pilot not lighting
first thing I would check is to make sure the quick disconect on the gas hose is fully connected,and that the cut off valve is tured on.Sometimes the orifice in the pikot assembly can become stopped up.(where you light it by the burner)you can check there by undoing the gas line at the compression nut on the assembly.the hole is really small and you can use a small needle to clear it.
Mar 28, 2009 | Frymaster Dean FM345EETC Deep Fryer
Frymaster Dean SR42G Deep Fryer Logo
64 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Paul Carew
Lawrence Oravetz
Dennis Boxerman
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
