KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher Logo
Question about KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher
Kitchenaid kudi01ilwh2 won't start
Posted by bobs on
Sam
  • KitchenAid Master
  • 3,247 Answers
By won't start do you mean that everything is set ok but when you press Start button then nothing happens.
In that case most likely the door is not sitting properly or the door latch or door switch is faulty causing the dishwasher to not start.
However, if nothing happens on the panel when you press buttons but power is there, then most likely the panel is faulty and can be replaced.
you can trace the parts in these diagrams.
Posted on Nov 03, 2011
My Kitchen aid cooktop model number KECC667BBL won't turn on
Mis-wired or the new control panel is faulty. Call them back, it is under repair warranty. The parts aren't cheap!
https://www.searspartsdirect.com/model/41v4g0ja62-000593/kitchenaid-kecc667bbl01-electric-cooktop-parts
Kitchenaid ice maker full of ice but won't release it
What is the model number of your unit?
How to start kitchenaid dishwasher
1-confirm power make sure breaker is not tripped or fuse is good and no tripped GFI's (no power obviously it won't work) 2-confirm water is on (the timer has a delay that it powers down during it's wait for the unit to fill with water 3-make sure the door is fully closed and latched properly (the door has a safety interlock to prevent the dishwasher from operating while the door is open -- think water sprayed everywhere) 4- beyond this if it is a new install and has never worked call your installer back
Kitchenaid ksb560 won't turn on. No power at all...
Take the base off and check the motor for continuity.
1helpful
The Whirlpool Dishwasher GU 2400 won't staart
Sometimes I have to push the cancel button on my Kitchenaid and start over and push the selection buttons again. and then push start. Don't know if this will help.
Microwave snot statrting
Hi it sounds like a bad door switch, cause they are so dangerous ,it won't let it run cause it thinks the door is open . they have safty door switches , If you don't know much about electricity don't go inside a microwave
KitchenAid Dishwasher won't drain KUDI01ILBL6
Do you have an air gap on your sink? Check it to see if its plugged.
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
