Hello, I have a Porter Cable 7500 watt generator (B&S Vanguard engine). The engine has a throttle control and also an Idle Controle switch (which is "off" as the manual it says not to use if you're using a Refridgerator/TV on the generator). May be a basic question, but how do I determine what the throttle should be set to? I currently have it running on full, but with only a fridge and freezer plugged in. Is there a general rule of thumb what the throttle should be set to, what i should listen for, etc...? Thanks!
The idle control switch allows the generator to go into idle when there is no demand form the appliances connected. This saves gas and increases the life of the generator. Damage can occur for some appliances like a refrigerator/freezer because the voltage and frequency are not prepared for the load resulting in a low voltage bad startup that will damage the appliance. Suggest that you leave the idle control switch off while any motor/electronic devices are connected.
The throttle control is likely a choke function for starting. These generators are designed for only one running speed to produce the necessary 60 cycles per second and voltage.
The following link is to a Canadian web site that later in the detail report describes the concern of idle control. In addition it provides good insight to the operation and use of portable generators
Hope this helps?
Understanding Portable Generators
The user manual see pages:
http://www.mikestools.com/download/Porter-Cable-Manuals/Porter-Cable-CTE300.pdf
Posted on May 06, 2017
SOURCE: I can not find the positive and negative
i beleive that this unit is a generator only,to flash it go to the armature and flash it there.
Posted on Feb 09, 2010
Dec 06, 2011 | Porter Cable BSV750W 7500 Watt Electric...
Aug 26, 2011 | Porter Cable 5,500 Watt Portable Generator...
Nov 13, 2010 | Porter Cable 6,500 Watt Contractor...
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
Sep 29, 2010 | Porter Cable Portable Generator BSV750
Sep 08, 2010 | Porter Cable 10,000 Watt 20 Hp Portable...
Jun 27, 2010 | Porter Cable 5,500 Watt Portable Generator...
Jun 20, 2010 | Porter Cable 5,500 Watt Portable Generator...
Dec 09, 2009 | Porter Cable Portable Generator BSV750
Nov 22, 2009 | Porter Cable 5,500 Watt Portable Generator...
789 people viewed this question
