Question about JVC DRMH20 DVD Recorder
I try to change the HDD. The old one is out of order, and ...lost by the last owner. I'd like to replace the H.D.Disk by a new one, put on it the right firmware, and hope it'll work :D ! So, 1/ Where could I find the Firmware ? 2/ How to replace it? Some Tips?!?? Oopps... My JVC product is : JVC DR MH20 SL DVD Recorder (December 2004) Thanks aLL 4 ur answers... c3d.
Posted by Cedric on
Bill Boyd
    Top Expert:
  • JVC Master
  • 53,812 Answers
Go to a computer shop and buy a kingston solid state hard drive-250 gig for around $65.00 aud
next obtain a copy of win 7 with a registrable licence code and insert it in a cd drive
turn the computer on and hold down the delete key until the bios screen appears
move to boot tab
select cd as first boot device , yes and hit the esc key
turn off the computer then restart it
the bios direct will activate the cd and load the program into the hard drive and you are up and running
when finished , go back to switch off and do the bios start again and this time set the first boot back to hard drive
A 250 gig sshd is equal to 500 gig disc type and will not fail as there are no moving parts
Posted on Aug 27, 2017
3 Related Answers
silly girl
yoav kleinfeld
  • 513 Answers
SOURCE: "loading" at startup
First, let's see if the player tries to read the disc. Load a disc and listen. Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable. Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word. This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces. You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try. If you actually see dust on the lense, then its just that simple. clean, close, play. Good luck
Posted on Jan 24, 2006
SOURCE: loading is flashing and can not do anything
my machine just has loading displaying in a flashing mode
Posted on Feb 12, 2009
Artie
  • 236 Answers
SOURCE: cd recording on jvc dr-mh20
You can record sound on DVDs (up to 8x -R), CD data discs cannot be recorded on your machine.
Posted on Feb 18, 2009
Tx1000 rd223av
HP has no issues with it, its near obsolete. 10 years old.
HP drops support after 10years
no OS stated, is this the virus magnet XP or now dead VISTA
that matters big time, the OS, state that first.
all hardware can be fixed. all can,! deep pockets and lots of spare time. sure.
all old PCs freeze!, for many reasons.
top causes (my worthless guess only fate wins is true )
1: virus infected , x
2: the main battery is shorted, take it out run on AC all day.
3: coin cells fail, all do , not one lasts 10 years (2-5 is spec from top maker ('copper top")
4: spilled drinks into IT.
5: HDD bad. dead or failing and freezing, sure. vast PCs are put in the land fill for this alone when you see price of the fix.
(new HDD + new cost of new OS + labor) ouch
now the HP point finger thing, sure there are limons.
many (vast) 2008 laptops had the GPU Nvidia solderballs from H3LL failure, HP and you victim.
if the screens does not do crazy things, its not Solderballs.
your PC came with VISTA new. is it still vista after 10 long years?
VISTA support ended at MS this spring
this makes getting vista drivers from MS real hard if not inpossible.
that leaves only HP page for driver, lucky you not deleted yet
see that word yet, hint hint get em which you still can now.
here.
the RTC battery coin cell is beach to change, page 62 and must be.
http://h10032.www1.hp.com/ctg/Manual/c00853874
the software for vista is here, (official) not fake or infected
as others post here (spam bs)
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-tx1000-notebook-pc-series/3185026/model/3185027
so if you put in any linux disk CD and boot if the Linux runs ok
then you lean in 5min that the OS on the HDD is bad or the HDD is bad.
things to check
fan blows? no packed in lint or overheating all vents clear.
COIN cell new? 2.9v to 3.3v good below that not good at all.
run a HDD test yet, that be next. in order here.
the BIOS can have a HDD test if lucky most do 2006 up. years.
The linux disk has nice smart test, for DISK
shown here.
see smart and full disk test using a boot LIVE LINUX
also ubuntu 17 disk, (boot stick) question one is LIVE
pick live and then pick search , try disk , pick disk
see here how. this is how I test all HDD,
http://www.pcdied.com/linux.html
I do it that way so corrupted VISTA cant get in the way of TRUTH.
Nov 09, 2017 | HP Pavilion dv5020us Notebook
GHDHU2 - lost users manual. need help setting up!
Plug the USB lead into your Macbook, wait for the new HDD to show on the desktop. Click on the new HDD and copy what you require to it.
If you cannot see the new HDD use utilities and navigate to Disk Utility, click on the new HDD and click on mount.
May 06, 2017 | Iomega Computers & Internet
Can I install a NEW 1T HDD where an old HDD failed?
In a lot of cases, the recovery disks you built may be looking for installation files (windows installation files) from a partition that is on the original drive of the machine. Your new drive would not contain this partition or the files. If you can STILL get into the old drive, I would consider putting both drives in your desktop.....and then use an disk imaging software to do a disk to disk clone of your drive rather than reinstalling Windows from the recovery disk. There are plenty of options for free cloning software.....just google free disk imaging, and you will probably find a ton of options with instructions. One thing to note....when cloning a drive be VERY careful when choosing your SOURCE and DESTINATION drives. Your SOURCE would be your old drive with your data, and your DESTINATION is your new drive. If you mess up that step, it will overwrite your old drive with the "blank" data from the new drive, and your data will be lost.
The other advantage to cloning, is you will get an exact replica of your current configuration. you dont need to reinstall programs or reconfigure things.
Mar 04, 2013 | Gateway SX2802-07 PC Desktop
I have a problen with a lap ibm 600x thinkpad . shows error 19990305
if your bios is loading up completely then you need to reinstall the OS with a disk. If the bios is not loading up all the way you need to go into your bios and reset it to the defaults. If you can't access the bios you need a new motherboard and unfortunately with laptops it is cheaper to but a new laptop than a replacement motherboard. You can rip out the HDD though and put it into an external enclosure to get all your old files. then once you have all your old files off of it you can format the old HDD and you have an external HDD for future back up :)
Aug 25, 2012 | IBM ThinkPad Computers & Internet
Replace internal hard drive
This have to be easy. Use small philips screw driver to open HDD compartment, there may be one or two other screws to remove, slide the HDD away from it's connector and take it out. If there is any cage, remove the HDD from it (4 screws at most). Replace with the new HDD and assemle in reverse order. Boot from the recovery CD and install the OS, device drivers and other software. Your old data will be on your old HDD. In case it is in good working order you can put it in USB cage and use it as external USB HDD to transfer your data back.
Apr 08, 2012 | Toshiba Computers & Internet
I am a new macbook pro owner. My new mac will not recognize my external wd mybook which is several years old. What do I do?
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in FAT Format.
6. Click Apply.
7. Done.
Hope it Helps..!!
Jul 07, 2011 | Apple MACBOOK PRO WITH PARALLELS NOTEBOOK...
My evo610c would not start and failed the HDD self test. I installed a new hard drive. It now passes the HDD self test, but will not go past the screen that says "not-system disk, replace and try again"....
Put the Windows CD disk into the CD-drive.
Turn the computer off.
Turn the computer on, and immediately look for a message like "press F12 to change boot order", or something like that. Tell the computer to first try to boot from the CD-drive. When it boots, the installation process will start.
Jun 23, 2010 | Compaq Evo N610C Notebook
HDD Recovery failed
I have had this problem intermittently for some time and have not found a solid solution for it yet. The HDD may be going bad or it may be a power supply or digital board problem. I just replaced the 3 bad capacitors on my power supply a few months ago, then the set started having HDD problems. As of now when I want to record, I have to unplug the AC power for a few seconds to get the relays to reset, then the HDD will start and be readable until the next power cycle. Sometimes I have to leave the unit unplugged until the power light goes out completely (capacitors drain) in order to get it to work. I'm still working on a final solution for this issue, but the set is a 2-man lift and a pain to open up.
Last time I had it apart, I noticed that the SATA cable to the HDD was strained where it came off the connector on the digital board since LG used a straight cable instead of a right-angle one. I just ordered a new cable and will let you know how it goes. I also wast to put in a larger disk at some point.
Jan 24, 2010 | LG 42LB1DRA 42 in. LCD Television
New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Feb 01, 2009 | HP Pavilion zd7000 Notebook
Replaced hdd on emachine w3615,light on mobo but it wont come on.
Hi ipackrat21, that little green led you see is telling you the motherboard has standby power. (Its supposed to be green & on).
Make sure the hdd jumper is set to, master without a slave). In a one hdd system.
When you replaced the hdd you also need to enter the bios menu.
In the bios you'll need to make some changes. First you should see the new hdd listed in the bios. (Normally it list the hdd by model). If your hdd is shown than go to the title "BOOT". You need to set the boot order. A normal boot order would list like so;
First boot device, Floppy disk drive".
Second boot device, "CR-ROM" drive.
Third boot device, "Your new hdd".
If your bios does not see your hdd you'll need to re-check the data cable from the board to the drive. (Make sure it is fully connected).
If the drive is an IDE/PATA make sure it has power. A 4-pin molex.
010e000.jpg Good luck ipackrat21!
Still have trouble, post it here.
Mike
Jan 14, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
JVC DRMH20 DVD Recorder Logo
54 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
