Question about Logitech X-230 Computer Speakers
Where can i purchase the audio cables that connect the Logitech X 230 sub woofer to my laptop and mp3 player
Anonymous
    New Friend:
  • 104 Answers
Usually you can purchase audio cables for speakers and sub-woofers from any or authorized PC outlets.
Just explain to the dealership what you want to connect it to and they will shoe you the right "jack" to buy.
G.
Posted on Nov 01, 2011
Connect Philips sw3440/37 powered sub, with no other components. I bought this powered sub at goodwill... How do I hook it up without the other components (dvd player etc.)
Unfortunately, I don't think you can connect this sub-woofer without the rest of the components of the HTS3440/37 DVD Home Theater System or a related Philips home theater system. The speakers in the system are hard-wired with a colored plug that you connect to the sub-woofer. Then you need connect the inter-connect cable between the sub-woofer to the DVD Player of the system. See the wiring guide in the Quick Start Manual or the User Guide available on the product support page: https://www.usa.philips.com/c-p/HTS3440_37/divx-ultra/support .
Sub-woofers that aren't part of a home theater system connect to a receiver with a digital audio RCA cable. One example is here: https://www.amazon.com/Mediabridge-ULTRA-Subwoofer-Cable-Feet/dp/B003FVYXY0 . Then the speakers also connect to the receiver.
Even if you find another Philips Home Theater system that is missing the sub-woofer, I wouldn't rule out a change in the pin arrangement for the inter-connect cable that would cause the system to fail. I can't find any sources for a replacement inter-connect cable; the part number isn't in the manual that I can find.
I wish that I had better news for you.
Do i have to have the sub-woofer in order for my logitech X-230 speakers to work with my computer?
Certainly any large speaker itself cant be used with
very weak computer out signal
The signal should have power amplification in addition to
voltage amplification to energise large speakers
1helpful
Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Only have the sub itself, Can I still use it and if so how?
Unfortunately you will not be able to use the sub-woofer by itself because the input for the Logitech X-530 has a special cable to connect to the sub-woofer. You could always try looking on eBay or Craigslist for replacement parts.
2helpful
I have jvc car audio model # kd-g335 how to connect my sub woofer?
You can not connect the subwoofer directly to your head unit. You need an amplifier installed to play the sub woofer. Asuming that there is an amplifier installed then: If your head unit has an RCA output on the rear, connect that to the LINE IN of your amplifier. Also there should be a Blue&White cable at the rear of the head unit.(amplifier remote) That should be connected the the remote terminal on the amplifier. (this will turn the amp on and off when the head unit turns on or off) Hope this helps. dreamsystems
How do you connect logitech speakers on the pc
1) plug the cable coming out of the satellite with the sub-woofer at the reat 2) plug the 3.5 cable jack coming out of the second satellite to the computer audio out ( generally green color connector ) connect the power adapter with the sub woofer
and you ready to enjoy the music. make sure yo switch on the the power adapter.
My Definitive Technology Supercube ii subwoofer is not powering on. I've checked the electrical outlet so it's not that. I suspect it might be a problem with my subwoofer cable but I don't want to take...
Unfortunately, the most common problem with powered sub woofers, including definitive technology, is that the capacitors inside dry out. To check the speaker, you can connect any line level audio source (like an mp3 player) to the speaker and see if it comes on. If it does come on, then you will know the speaker is ok. If not, then the speaker will need servicing. Powered sub woofers are not usually a DIY project.
Logitech x-230 speaker system
Ironically enough, I went on here because I have the satellites but no subwoofer! LOL, what are the odds. Anyways, if you happen to receive this information, can you please email me at [email protected]?
Like I said, I'm searching for the same exact information for a similar problem and this would REALLY help as I can't power the speakers without this.
Hook up z-5500 suround to a tv
The Sony has (http://b2b.sony.com/Solutions/product/KDL-46S4100)
Digital Audio Output(s): 1 (Rear) Optical Digital Output
The Logitech speakers have (http://www.logitech.com/index.cfm/speakers_audio/home_pc_speakers/devices/224&cl=GB,EN)
Source Inputs:
Digital optical for DVD or CD players, PlayStation®2, Xbox®**
To do this, you need a Digital optical cable--Search Googe for this: Cables Unlimited Pro A/V Series - Digital Audio Cable (optical) - 6 ft
Should work.
Logitech X-230 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Mandeep  Singh
Mandeep Singh
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
