Your fan or heater likely shorted out and burned up, causing your one of the main fuses to blow due to the spike in current. You will need to determine what burnt up and replace it before replacing the fuse, or you may create a fire hazard or cause further equipment damage. Also double check any changes to wiring to make sure that everything is hooked up properly.
Ck'd fuses, none blew. How or what do I ck to find out what fried?
The easiest way to narrow it down will be to check visually for where the smoke originated. It is possible that a wire simply overloaded and burned through. You may have to use a resistance meter and the diagrams from your manual to check the wires that feed power to the ignition switch, there should only be a couple of them. Also make sure that none of the power wires that connect to the positive pole of the battery are wired to, or touching bare metal on the body of the car. **Important: Do not check resistance with the battery connected or you will damage the meter or short out your system.
This can be a very lengthy and error prone process. If you know someone with electrical experience who can give you a hand it may save you a lot of headaches. Unfortunately, I can't determine much more without actually testing the wiring.
