Looks like your bearings have gone if you can not move with hands looks like you need a new machine as to pay someone to fix this is a lot hope this helped
It could have an imbalnce in the drum because the load is uneven, or your machine could be uneven on the floor,, try checking for the level of your machine
Remove the lower rear panel of washer, remove drive belt and spin drum by hand, watch your fingers!!!.
If it feels rough, or you can hear it rumbling or grating, then the bearigs have gone, there should be little or noise at all when you spin drum
I suspect that the main drum bearings have failed.
Remove the belt, and from the front spin drum by hand, if it feels rough or is rumbling or noisy, then drum bearings have failed.
Can be expensive!!!!
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Remove drive belt, and spin drum by hand, if it feels rough or noisy, then the main drum bearings are worn.
If no noise from drum, could be a motor prob.
Please rate ,my solution.
Thanks.
Remove drive belt, and spin drum by hand, if noisy or rough, then bearings have failed, if no noise, then could be suspensioon leg problem.
Please rate my solution.
Tghanks.
Remove lower rear panel of washer, remove belt and spin drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then look elsewhere for prob..Could be noisy motor, or loose concrete balance wieght.
Thanks.
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible.
Regards
Advisor
