Question about Kenmore Washing Machines
My HE2 plus front load washer does not want to start. Everything is fine. Turns on right and I'm able to change the type of load I want. When I press start it double beeps and does not start. What can be the problem.
Posted by croblesm on
john_cross
    Brigadier General:
  • 6,277 Answers
Try this!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Oct 31, 2011
What could be the reason that my Kenmore HE2 Plus Front Load Washer won't start?
Hi, Could be the door switch, make sure the door is shutting completly then try to start.
Aug 15, 2014 | Kenmore HE2 Plus Front Load Washer
He2 maintenance procedure failure
unplug for a minute and see if it resets the cpu.
Jan 21, 2018 | Kenmore HE2 Plus Front Load Washer
My Kenmore front loading washer will not open
what is your model number is then we can get started then
Jan 17, 2013 | Kenmore HE2 Plus Front Load Washer
Loud noice in the spin cycle while going fast
What is the complete model number of your unit?
Dec 04, 2012 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 plus front loader washer no water and no error code.
there are 1 or 2 valves that go into the m/c where the pipes from under you sink etc go to the washer these are two valves some times these fail and dont let water into m/c hope this helps ivan
Sep 27, 2012 | Kenmore HE2 Plus Front Load Washer
Clothes with pin holes are seen afetr washing/drying with He2 plus/He Washer dryer combination
Are you over loading the dryer? I know those combo machines can't dry a lot at once
Apr 28, 2012 | Kenmore HE2 Plus Front Load Washer
HE2 Plus Washer starts then shuts off immediately.
Aren't microprocessor controlled appliances wonderful? Especially when the code is flawed! No wonder the space program bit the dust!
May 12, 2017 | Kenmore HE2 Plus Front Load Washer
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer wont start
open the back on the right side on the bottom panel,you well see lots of wires,NOW START tagging wires uses two people for this.it may be easy to change switch out
Jul 04, 2010 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
47 people viewed this question
Michael Thomas
Michael Thomas
Lawrence Oravetz
Vernon Taylor
