Nikon D40x Digital Camera Logo
Kim Gallagher Posted on Oct 30, 2011
Nikon d40xcamera...sd card won't click into slot
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Nov 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
Helped
1428
Points
15
There is a lock on the side of some sd cards try checking if there is one.
1helpful
My memory card for my d3100 won't format, I've
Dear Madeline Birch,
I suggest, you use the laptop to format your card. The process is as follows.
- Insert the SD card in the SD Card slot available on your laptop. Enter My Computer, and right click on the icon which represents your card. Format it from there as you would do for any other USB data storage.
If you don't have a laptop, or your laptop doesn't have the SD Card slot. Then, you should purchase an SD Card reader. The process mentioned above would be similar.
If all fails. I recommend you to get another card, as the card may have been corrupted.
Hope I was able to sovle your problem.
Regards,
Rebel K
Jan 13, 2013 • Cameras
1helpful
Nikon D40 SD card slot broken
If you feel up to doing the replacement yourself, you may order the part here.
1helpful
Nikon coolpix S8100 won't power on even with new battery.
10 replace batteries or recharged very well the batteries.
2) clean very well the contacts batteries from oxide, dust, dirty. or corrosion
3) batteries loaded in WRON direction
4) batteries is NOT the right type
5) poor contact between battery and cover , clean and adjust it .
6) Memory card slot/battery covert is open
God bless you
Why wont my toshiba sd card read on my camera nikon cool pix ?
Make sure your memory card is an SD card and not an SDHC card. If it's larger than 2GB then it won't work with the 3200.
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
1helpful
My D50 Nikon camera reads CHR I bought a new SD Card it is 4G can that to big
The D50 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it will only work with devices specifically designed to accept SDHC cards. The D50 wasn't. It only works with SD cards, 2GB and smaller.
SD slot won't read card
I had the same problem. You have to buy the specific card for that SD slot and it has to be an original one. Mine worked with the Micro SD 4gb.
Memory card won't stay in the slot, won't read.
service camera at Nikon. mechanical SD card lock failure
11helpful
4answers
Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
