Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven Logo
Question about Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven
Fridgidaire wall oven not heating properly.The bottom oven works well but the top oven does not come up to temp. If it is set to 400 it may only come up to 330 and that is not consistant, it may not hold at 330.
Posted by Mike Stobbe on
5 Related Answers
Anonymous
  • 25 Answers
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
Posted on Dec 12, 2007
Anonymous
  • 1314 Answers
SOURCE: Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Posted on Jan 11, 2008
Anonymous
  • 1239 Answers
SOURCE: oven not heating to proper temp
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Posted on Nov 16, 2008
Anonymous
  • 291 Answers
SOURCE: Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Posted on Aug 31, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: frigidaire pleb30t9fcc double oven -- top oven
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 18, 2010
Frigidaire PLEB30T8CCB Double wall oven - heating to temp, but not maintaining.
Your wiring diagram and parts schematics are here in the link below. Normally the bottom element does glow read hot after a couple of minutes. Broil elements last a lot longer because they aren't used as much. There is only one Control Board. If I was guessing, I would say the temperature sensor is at fault. Elements either work, or they don't, but you can easily test continuity with a meter. Many parts are discontinued.
https://www.searspartsdirect.com/model/3f7nkrfnvp-001428/frigidaire-pleb30t8ccb-electric-wall-oven-parts
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
GE oven JKP26GOP2BG wont heat
either the temp sensor probe in the oven cavity it open/shorted or way off scale and telling the control board the units up to the temp set point,theres a way to test these with an ohm-meter for resistance at certain temperature but i dont have the chart for that test,it may be inside the unit if you can locate it
Dec 02, 2012 • Ovens
1helpful
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 • Dacor Ovens
2answers
Fridgidaire Wall Oven will not heat
1) If there is a reset on the electronic panel try that.
2) Set the temperature to 200 and see if works then.
3) Put a baking tin in the oven with a piece of meat in it.
4) Uninstall the Wall Oven and take the back off and check the wiring for the elements and the convection fan.
3helpful
2answers
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Elements do not heat to proper settings
If both elements are not working properly then the problem is either the temperature probe or the control board.
Replace the temp probe first.
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Top Frigidaire Ovens Experts
Marvin
Marvin
David Shaub
nu267
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
