Hotpoint Ultima WF860 Front Load Washer Logo
tina hayes Posted on Oct 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Very noisy spin wf860 - Hotpoint Ultima WF860 Front Load Washer
Anonymous
Level 2:
Sergeant:
  • Expert 389 Answers
  • Posted on Nov 02, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
389
Questions
0
Helped
128781
Points
887
Hi if you turn the drum by hand can you feel a slite rumble if you can it will be your drum bearings common problem on a machine that has had alot of use
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
Drum has stopped spinning hotpoint wt960
looks like your bearings have gone if you can not move with hands looks like you need a new machine as to pay someone to fix this is a lot hope this helped
My HOTPOINT ULTIMA WASHING MACHINE wt960 is very noisy on the spin cycles...is there a need for oiling or what else can I do..?
It could have an imbalnce in the drum because the load is uneven, or your machine could be uneven on the floor,, try checking for the level of your machine
I have a wf860 Hoptpoint washing machine and it was quiet until I washed some cushions in it. Now it moves around when it's on a spin and it's very noisy. Can this be fixed?
You might need to check if it is level also that if all the feet are stable on the floor. if all this is fine it is probably the suspension witch is on the way out and needs replacing. hope this helps
1helpful
Noise when spinning
Remove drive belt and spin drum by hand, if it is noisy, or feels rough, then the main bearings have failed, if no noise, then check for noisy motor bearings.
Please rate my solution.
Thanks.
2helpful
VERY noisy spin cycle wf860
it sounds like your concrete block is loose. unplug machine and remove lid check block on top of drum there is also 1 at the front of the machine below the door seal. WARNING DO NOT OVERTIGHTEN THE BOLTS.
1helpful
2answers
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
2answers
Noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
