Question about Hotpoint RFA60 Bottom Freezer Refrigerator
Althoughi put my settings on number 1 or 2 aboute 7 or 8 weeks it realy thick of ice.and i have to keep on thawing it out.RFA60.FUTURE
Posted by BRIANTHOMAS on
5 Related Answers
Anonymous
SOURCE: hotpoint future RFA60 Fidge Freezer
I have lost the instruction booklet for my Fridge Freezer RFA60. How do I defrost the freezer?
Posted on Nov 08, 2008
EllaWatson25
Ella Watson
  • 725 Answers
SOURCE: Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Posted on Aug 14, 2009
Boneebone
  • 973 Answers
SOURCE: Ice build up on coils in freezer GE Profile PS123NC/psI23SC
You may need to replace the automatic defrost sensor.
Posted on Jun 05, 2010
machinetech7
Jason Kennidy
  • 1344 Answers
SOURCE: recently noticed ice accumulation in
You have a clogged drain. Usually I remove the ice, take a screwdriver and tap it into the drain hole. Then I pour hot water down it until I see that the water is draining all the way out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Oct 31, 2010
Grant Smith
  • 246 Answers
SOURCE: I need a new door for the freezer section of my RFA60. Where can I get one?
Instead of replacing the door--- just cover it instead.
Go to www.applianceart.com -- These guys specialize in refacing your appliances. Their motto is Don't replace your existing working appliances -- Reface them. They offer magnetic and vinyl options that will fit over the existing surface. I believe the vinyl option will work best for you.
They have solid colors, designs, textures and even stainless steel options.
Worth checking out.
Posted on Dec 09, 2011
For the past couple of weeks, the freezer will loose its cool enough to thaw or partially thaw what is in it, but two or three hours later it will be frozen again. Keeps going back and forth. Ideas?
possible problem thermostat or freezer setting to close to one setting
reset to a bigger number as the numbers work opposite to the fridge settings ( 1 is close to 0 degrees and 20 is -20 degrees ) where as in a fridge 1 is close to 0 degrees and 5 is + 5 degrees above 0
Sep 10, 2016 | Refrigerators
Ice dispensor not working
Most likely reason water not dispensing out door 1) You can turn up the temp in the freezer to see if it thaws in a couple of days, 2) Turn on the dispenser light and leave it on, will thaw the line and keep it thawed, 3) the water tank is frozen in the fresh food side (you can defrost with a blow drier) 6) the fill valve went bad or plugged ( power to fill valve but not opening) ($50) 7) Micro switch went bad in the dispenser for the water side 8) Door switch bad 9) Install a heater kit to thaw the line and it will keep it thawed ($35) PN#1381601 10) You can replace the whole door if insulation gone bad in door ( $500 to $800) 11) a broken wire to the fill valve ( no power to fill valve ) 12) with GE refrigerator bad dispenser boards or control boards ($400 and $150) 13) plugged, faulty or incorrectly installed water filter let me know more about you problem and I can help..
Sep 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
My Samsung RS267LBBP side by side has low water preasure at the dispensor after only three weeks after changing the filter. I've changed it three times with the same result. Also, I've noticed the ice...
with samsung refers the control board and ice maker have be updated Most likely reason water not dispensing out door 1) You can turn up the temp in the freezer to see if it thaws in a couple of days, 2) Turn on the dispenser light and leave it on, will thaw the line and keep it thawed, 3) the water tank is frozen in the fresh food side (you can defrost with a blow drier) 6) the fill valve went bad or plugged ( power to fill valve but not opening) ($50) 7) Micro switch went bad in the dispenser for the water side 8) Door switch bad 9) Install a heater kit to thaw the line and it will keep it thawed ($35) PN#1381601 10) You can replace the whole door if insulation gone bad in door ( $500 to $800) 11) a broken wire to the fill valve ( no power to fill valve ) 12) with GE refrigerator bad dispenser boards or control boards ($400 and $150) 13) plugged, faulty or incorrectly installed water filter let me know more about you problem and I can help..
Sep 26, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Aug 13, 2009 | Refrigerators
Freezer keeps thawing. There was an ice build up.
Check the "flap" in the door where the ice is released. If it has come undone it will thaw the ice in the maker and into the freezer...
Jul 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Wall ac unit keeps freezing up inside.
Do not run it on maximum cool and fan on low. Freezes up all the time this way.
May 01, 2009 | Heating & Cooling
Fan in freezer very loud noise
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
Feb 01, 2009 | Freezers
Whirlpool side by side, 7 years old. not making ice
try using a hair dryer to thaw out the trough and remove the ice. please note the ice will run all the way up into the tube where it comes thru the cabinet.
this may have occured from your recent filter change as a new filter introdues alot of air into the water system and will cause these tubes to freeze up. in the future right after you replace your filter be sure to run aout 1/2 to 1 gallon of water thru water dispenser to clear air out of system. thx peyton
Jan 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hotpoint future RFA60 Fidge Freezer
Nov 04, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
