SOURCE: Slow coffee stream and smaller brew size with B70
I had the same problem. In my case the needle that pierces the cup was clogged. All you need to do is unfold a paperclip (small and not plastic coated) and push it down through that needle to clear the blockage.
My unit works better then ever!
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
I had the same problem, contacted Keurig and they suggested the descale procedure, which did nothing. The brew size was very small, the display would not let me select the size, and water was being pushed back into the reservoir. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cups, and when the reservoir was empty of the solution let sit 2 hours while unplugged and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since. This may work for you...
SOURCE: My machine only brews 1/2 cup of coffee. I have
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
SOURCE: My keurig will not brew a full cup and I have
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
