My washer dryer won't switch on
My daughter called out a repair guy who said it was the main circuit board
Posted by edith on
Jeremy Moore
  • 1,940 Answers
If the repair guy tested the machine, and determined that the Main Circuit Board is bad, this will cause the machine to not come on. Replace the Main Circuit Board and you should be good to go.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Nov 09, 2011
LG 29PFL4908/F7 HOW TO REPAIR GUIDE CAN YOU GUYS HELP AND WHAT I NEED TO LOOK FOR
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sep 29, 2016 | LG Televison & Video
I need help with my television repair.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 19, 2015 | Philips Televison & Video
Oven won't keep temp.
I would try another control board. I have gotten 2 new ones before that were bad right out of the box! It happens all the time.
Dec 27, 2013 | GE Profile JGS968 Gas Kitchen Range
Where can i buy main unit board for my b550 set? help!
Sounds right to me, try calling 1-800-samsung to find nearest service/parts center.
Nov 15, 2009 | Samsung LN37B530 37 in. LCD TV
Power jack on acer aspire 3050 got very hot. now it doesn't work. Is the laptop fried now?
this model is very cleverly designed. the power connector is actually on a smaller daughter board that is connected to the main board, the problem is most likely the damaged daughter board (sometimes called the power board) so all you need to do is replace this daughter board, you should be able to find good deals on eBay
Sep 25, 2009 | Acer Aspire 3680 Laptop
Replace main board on LG 42LC7D-UB
Try this place, http://www.shopjimmy.com/catalogsearch/result/index/?q=42lc7d-ub&p=2
I the best place I know of to get parts at a good price.
There are a couple of boards that have different part numbers. You'll have to match the part# with yours. It maybe out of stock, but click on it. Then click on "find other products with this part number". Then all the main boards show up with that part number. A couple of them should be should be in stock.
Apr 16, 2009 | LG RU-30LZ50C 30 in. HDTV-Ready LCD...
not sure what you're referring to as a "main board", but heres the LCD Control Board for the TV
http://cgi.ebay.com/LG-42LC7D-UB-LCD-CONTROL-BOARD-6870C-0119A_W0QQitemZ150277759127QQcmdZViewItem
Mar 13, 2009 | LG 42LC7D-UB Television
Fridgedare Electric Range
Try unplugging the range from the power supply and switch off the circuit breaker. Wait about 5 minutes and replug the device and then turn on the breaker and see if that helps.
If that doesn't work, then it looks like the logic board has stuck, and the interlock switch will not work. You may have to call in a repair guy for this, to either unlock the switch or fit in a new assembly.
Please let me know how it goes with breaker, and any developments, maybe we can troubleshoot further before having to call the repair guy :)
May 28, 2008 | Kitchen Ranges
Dewalt dc011 ! wont charge batteies
send your radio for repair. till the guys at the service for grc repair cost. very economical rather than you do it your self if you are not sure of the problem. radio need 3 circuit borad or also a charger
Jan 05, 2008 | Dewalt DC011 AM/FM Radio
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
