Why is my visiontek 21g model only accept idea sim card ?
My visiontek fwp instrument model no 21g only accept idea simcard plz help me to make access with all the gsm sim thank you.
    New Friend:
This is because the machine is programmed to work with idea sim only [pco] this could be unlocked by a software upgrade by visiontek technician
Posted on Feb 01, 2012
Insert sim
What is your mobile model?To insert simcard,the following conditions should be satisfied....
1)The mobile should be unlocked to accept the sim card
2)The mobile should have the sim slot (most CDMA phones do not have that provision)
3)The simcard size should be supported by mobile phone.
Now,if your mobile is locked with a particular network then you need to unlock it.For that you can either approach the respective network provider or third party unlocking services like Simpleunlocking.com or unBBlock.com (This is specifically for Blackberry phones) and unlock your mobile.Once your mobile is unlocked the sim slot will either be in the side or above or below the battery depending on your mobile model.If you search in Google you probably will get a more clear idea about where your sim slot is located.Once you find the sim slot remove the sim card and note down the position; replace it with the old sim card(it should support the phone sim size specification).
Jul 12, 2013 | Cell Phones
Visiontek 21g fixed wireless phone screen display not repnding
this is hardware problem check display and display related parts
Sep 11, 2012 | Cell Phones
My sim card is blocked by giving wrong password im finding puck code o unblocked it plz help me to find sim cards puck code
Hi!you can find your simcard PUK code at the back of the holder of your simcard when you buy it..You can find there also the initial PIN code of your simcard.
Aug 14, 2011 | Home
Not accepting any sim card and show error "start
You phone fails to recognize,the a look at this causes,might 1 of the problem is listed below.
(solutions are already indicated).
* your simcard might be corroded and need to be clean using a pencil eraser.
* simcard socket lock might be losen and need to bend a little bit downward to reach the contact of the simcard.
* simcard reader or terminal pins is dislocated and not properly align,need to fix in proportion or re-aligning.
* simcard reader or terminal and its pin is corroded and need to be clean using any rust solution and a cotton.
If the above method does not work,simcard IC might be damage and need a parts replacement,by this time,you need to bring it to the service center to fix this problem.
Aug 03, 2011 | Nokia 5220 XpressMusic Cellular Phone
How to unlock visiontek fixed wireless 21g phon to work with any sim card
To get the security code/restriction code to unlock thecell phone from the current cell phone provider so you can use it with adifferent phone provider, Please click on this link and follow my instructions:- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then this WEB siteit provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw Try this WEB site also - UnlockFree http://www.unlock-free.com
Oct 29, 2010 | Cell Phones
My idea sim is blocked. it is asking for puk code. plz help.. my sim card no. is 89917811060443421618- Guest
hi, puk code is coming with network provider.. So you can call to Idea customer care and give your simcard number and they will provide you..Puk code...Hope this will help you....Thank you....
Nov 05, 2009 | Nokia 1100
BenQSIEMENS JASB1A want another sim to operate wid instead aircel
i have this model benQ-SIEMENS JASB1A ....2 things it is locked and 2nd i don have any sim card right now ...but i want to operate with different simcard.. plz send me sim code
Oct 03, 2009 | Samsung Blackjack SGH-I607 Smartphone
Wont accept sim!
HI friend,
First of all I am not too old to be called as Sir alright?
Ok here is what you do,
remove the simcard from the cellphone, gently rub it clean with a clean soft cloth(a lil dilute spirit wud be helpful) and then insert the simcard back into the sim card slot.It works 99.999%
Have a great day:):)
Plz rate me for my solution so that I can improve myself and be more helpful:):)
Prasanth83:):)
May 25, 2009 | Nokia 5800 XpressMusic Smartphone
Computers & Internet Logo
394 people viewed this question
Ekse
Marvin
Marvin
