Question about Jandy Lite 2 Natural Gas Pilot Light Heater
SOURCE: Pool heater leakage
Chances are that the header or manifold is cracked. usually the heat exchanger themselves are not damaged from freeze, but either the rear manifold (header) or the front header (the one that pipes go in and out of). Sometimes both. Replacing the entire heater is not necessary, about $200 in parts usually. We have a schematic diagram of the LJ heater here: http://www.poolcenter.com/parts_heaters_lite2_lj_2003-present_pg1.htm
Rob Cox
POOLCENTER.com
Posted on Jan 28, 2009
SOURCE: Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
Posted on Feb 18, 2009
SOURCE: getting error code 188E on Jandy Model LT Lite 2
press the arrow key for 10 sec this will reset the heater. if code replace control board, if not enter time date and set temptures for pool and spa
Posted on Oct 16, 2009
SOURCE: FL 4 error, Jandy Lite 2 pool heater
I believe you may have a draft restriction and this may stop the start up diagnostics. The draft detection switch is sometimes restricted or weak. Common problem. Tap the gas valve to see if the winter has caused the valve to seat heavily and stick.
Posted on Apr 25, 2010
Jun 15, 2014 | Jandy Laars Lite2 Lj 250,000 Btu Heater
Sep 28, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
May 24, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Jun 06, 2009 | Jandy Laars Lite2 Lj 250,000 Btu Heater
Feb 16, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Feb 15, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
50 people viewed this question
