Question about Turbo Air MSR-49NM Refrigerator Commercial
Turbo air TSR 49SD keeps blowing breaker, doesn't cool but all fans run. Held down Turbo Cool & down button and pushed up button with no result.
Posted by Joe Wollman on
1 Related Answer
Dennis Boxerman
  • 1305 Answers
SOURCE: Cannot control temp, freezing everything Turbo
http://turboairinc.com/TB-Service/Service%20Manual%20%20-%20April%202008/TSF-49SD.pdf
check out this manual and see if your answer is there.
Posted on Jan 15, 2011
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Need to replace door gaskets
Emmie,
There are two gasket options for that model! If you have your unit's serial # we can ID the exact gasket you need. Replacing your gasket is a simple process and it looks that your gasket is a simple snap in option. Here's option1 http://www.coolergaskets.com/turbo-air-gasket-25-1-2-x-53-1-4-1/ & Here's option 2 http://www.coolergaskets.com/turbo-air-gasket-25-1-4-x-53-1-4/
It looks like both gasket options are made out of the same profile material but the dimensions changed per when the unit was manufactured. Double check your existing gasket's dimensions to determine which option is the best for you. Or shoot us an email or give us a call with your Model and Serial # and we can narrow it down for you.
855-288-2259
[email protected]
Aug 03, 2012 | Turbo Air TSR-49SD Stainless Steel...
I have a Turbo Air 49SD that the manufacture recommended amount of refrigerant charge is 12.7oz R134a. When I weigh in that amount, why does it appear to be undercharged. The suction line keeps freezing up...
since you did not supply the entire model number, don't know if this is a cooler or a freezer. if a freezer, -10 is good. if a cooler, not good. could be multiple reasons for low pressure if a cooler. you should also consider the high side pressure too as this can also help indicate a short charge. more info is needed to continue.
Feb 11, 2018 | Turbo Air TSR-49SD Stainless Steel...
I want to know the wire connection to compressor
MOst common are left to right start,common .run. Russ
Jul 19, 2009 | Turbo Air TSR-49SD Stainless Steel...
No cool air. blowing warm air
is breaker for condenser tripped---has it been running before -----is fan on outdoor ubnit running?
Jul 02, 2009 | Amana Heating & Cooling
One unit runs a while, powers down, other unit blows transformer
you say it keeps blowing the transformer? you mean circuit breaker? if it is the circuit breaker, have the wiring checked for a short, if no short do a ohm test on the compressor. it may have shorted out internaly.
May 31, 2009 | Haier HC48C1VAR Central Air Conditioner
Radiator Cooling fans pull or push air (93 Chevy Lumina 3.1 L) ?
A radiator fan is designed to pull air to pull air through the radiator to help cool it, while blowing the air on back across the engine to try to assist once again at keeping the unit running cool as to not over heat.
Apr 14, 2009 | 1993 Chevrolet Lumina APV
Turbo Air MSR-49NM Refrigerator Commercial Logo
Top Turbo Air Refrigerators Experts
Dennis Boxerman
Lawrence Oravetz
john h
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
