Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezeing food, milk fruits no control over it
Posted by scott thurber on
Carl Schulzetenberg
  • 1,543 Answers
Most likely, the damper door in the air control tower at the top back of the refrigerator section has broken, so that cold air from the freezer is entering the refrigerator whenever the compressor is running, instead of only when the refrigerator section needs more cold air. I beleive you will need a part number WR49X10091 to repair it.
Posted on Nov 16, 2011
What foods are low in potassium?
Almost all foods have some of it, so the serving size becomes important. For a low-potassium diet avoid LARGE servings of
- whole grain bread, brans, granola
- sports drinks, all milk products, soy milk
- apricots, avocado, bananas, melons, oranges, pears, dried fruits
- baked beans, raw cabbage, raw carrots, olives, potato, pumpkin, spinach, tomatoes, most bean types
- clams, most fish, most beef types
- salt free soups, low-salt and salt substituted foods = avoid these completely
- peanut butter, peanuts, chocolate
Note that this list is NOT exhaustive and can be eaten in smaller quantities, 1/2 cup or so.
Low potassium foods are
- white flour and white breads
= cakes and pies without chocolate or high-K fruits or nuts
- apples, apricots, blackberries, cherries, grapes, mandarins, peaches (drain syrup off), pineapple, plums, strawberries
- asparagus, green beans, cooked cabbage and carrots, cauliflower, corn, eggplant, lettuce, fresh mushrooms (not canned), onions, green peas, zucchini
- chicken, turkey, tuna fish, eggs
- almonds, cashews (1 oz)
- cheddar chesse, cottage chess (1 oz)
Again this list is NOT exhaustive. For complete info see a dietician, or do an exhaustive Google search eg
http://www.uptodate.com/contents/low-potassium-diet-beyond-the-basics
Jul 24, 2016 | Cooking
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Is there a large selection of freeze-dried foods?
Huge! You can find almost anything you want that has been freeze-dried, you just have to know where to look. Many companies now carry not only the basics (fruits, vegetables, protein); they have become very creative and learned to freeze-dry items like milk, full gourmet meals and even ice cream.
Jul 31, 2012 | Camping, Backpacking & Hiking
Food freezing
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 23, 2012 | Dometic RM2652 Refrigerator
My ge profile arctica is about 9 years old. It is freezing food in the refrigerator, temp control is set at a 4 and the thermometer inside reads anywhere from 28 -40 in various areas of the fridge. Milk...
first run the diagnostics on the unit from the tech sheet inside the unit,then if thermistors are bad replace these there are 2 one on the left and one on the right wall in both fridge and freezer,if good per diagnostics then replace the electronic damper door located between the fridge and freezer compartments in the upper left hand corner of the fridge behind the plastic grille as these doors break and jamb open or shut and the temps can no longer be regulated during the diagnostics tests you can hear this door operate if its operating correctly,lastly,if these fail to solve your problem,replace the main control board in the back behind a panel
Aug 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge is freezing my milk, lettuce and fruit. The temp was set at the recommended 38 degrees. What do you recommend?
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
May 09, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
Jan 20, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Food in fridge is freezing.
I need your model number, you may have a problem with your thermistat. Sears uses a different model number system than everyone. The model number will look like this 231.0564879 for example. Or yours may have electronic vents. Let me know, Thanks, Sea Breeze
You may need to contact me because Fixya has a problem letting me know if you respond.
[email protected]
Jul 20, 2009 | Kenmore 53082 / 53084 Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
133 people viewed this question
Top Refrigerators Experts
gbob59
Marvin
Marvin
