Question about Palm Treo 700w Smartphone
Sbt140 pair code - Palm Treo 700w Smartphone
Posted by Stephen Caldwell on
Bury car kit for 9320 pairing code
the pairing code is written in ur car guide. if there is no code there then when pairing u can put any number and write it on ur device to complete the pairing.
(some cars have their pairing codes in their guides so check it)
good luck
Feb 17, 2013 | Research In Motion BlackBerry Curve 9320 -...
Describe your pairing code for nokia ck 7w Problem i just need the pairing code
There is no default pairing code for the phone. You have to enter any pairing code and then enter the same pairing code in other device.
However, if you are trying to pair Bluetooth headset, check the headset manual to find its default pairing code.
May 24, 2011 | Cell Phones
What is the numeric keycode for pairing bluetooth? Jabra BT2035
As you pair the bluetooth in your computer and a bluetooth device, it gives you a pairing code, only if needed so, like the keyboard. The pairing code is seen in the computer, and is generated by the computer as you click on "create a pairing code". For other devices, a pairing code is NOT required.
Thank you for visiting FixYa!
Apr 25, 2011 | Computers & Internet
Code for sony dr-bt100cx bluetooth
Hi, when you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope that helps...
Thanks for using fixya.
Nov 25, 2010 | Sony DRBT100CX Bluetooth Headset
How can I put use it on my samsung phohe
Hi, Problem solved. All you need to do is to know how to pair the headset with your phone. Ones you pair the phone to your headset,your done..
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Hope it helps...
Oct 29, 2010 | Mizco Radio Communications
I need need pas key for plantronic 220 pairing to a blackberry 8300. [email protected]
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Sep 14, 2010 | Cell Phones
My nokia 2330 classic doesnt pair with my parrot 3200 ls color. after synchrinsing them unable to get authorisation code
Take care.
Aug 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
I need pass key for Jabra BT530 to pair with cell phone.
Take care.
Aug 06, 2010 | Cell Phones
How to put a hbh705 into pairing mode
Take care.
Aug 06, 2010 | Sony Bluetooth Headst HBH705 Sandcolor...
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
HOW TOCONNECT BLUETOOTH
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
Palm Treo 700w Smartphone Logo
95 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
NOEL
NOEL
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
