Question about GE WDSR2080D Top Load Washer
Water overflows and does not agaitate on GE washer model wdsr2080d5
Posted by Joe Prager on
chris
    New Friend:
    Problem Solver:
  • 16 Answers
Sounds like the mixing valve or pressure switch is bad
Posted on Jan 03, 2012
5 Related Answers
Robert Hirst
  • 833 Answers
SOURCE: My GE washer wont stop
You have a problem with the water level switch.  It is located in the base of the machine below the tub.  Replace it and you'll be fine.
Posted on Nov 20, 2008
Anonymous
  • 117 Answers
SOURCE: GE Washer WHDRR418E1WW overflows the tube. Yikes.
A washer that over flows in the fill cycle sounds like a faulty pressure switch. Part # WH12X10069 and 10 on this diagram. If it overfills the tub when the washer is off it's a faulty water valve. Best of luck Ryan
Posted on Feb 25, 2009
Anonymous
SOURCE: GE washer won't spin
Have you tried to blow out the air in the tube that connects to the water level switch control? Sometime that will get blocked. You will need to make adjustments here because the air in the tube determines how much water fill the drum.
Posted on Apr 05, 2009
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: My GE washer (modelWBB4500E1WW) overflows about
Remove the front panel by using a putty knife to depress the retaining clips at the seam where it meets the washer top. (one on each side) Take the thin hose off the lower left side of the outer tub and clean it out. A short cut would be to cut off an inch and a half of it, but that's a one time fix, then the hose starts getting too short. To help prevent re-occourance, run a small hot load with a couple cups of bleach (no clothes) every few months. Make sure to rinse the tub on the largest level to prevent bleach damage to your next wash load.
Posted on Oct 18, 2009
Testimonial: "Thanks!"
Anonymous
SOURCE: Our GE Select Washer 7 cycle extra heavy duty
My agitator is not working so I assume it is the clutch under the agitator but I can not remove the Agitator. I have only tried pulling up on it using lever and brut force.
Posted on Mar 17, 2010
Water level control switch not working. even i set water level to very low it just keeps filling and has overflowed. i am guessing that the switch needs to be replaced.
It depending on exactly what your seeing that will determine the problem.
Does your washer start agitating and keep filling?? if yes it does start agitating and the water continuies to fill try disconnectiing the power and if it keeps filling what would be wrong is that the water inlet valve is sticking open and it would need to replaced
If the washer continues to fill and does not start agaitating would be a defective water level switch as you suspect it may be.If ya disconnect the power and it STOPS filling replace the water level(pressure) switch.
GENE
Oct 02, 2011 | Kenmore 24032\24036 Top Load Washer
How to remove the agitator on a GE ProfileWPSR3120W0WW? The utube video (describing a bolt at the bottom) does not describe accurately what we have. Softener dispenser removal only yields a clear plastic...
Your washer is close to the one in the video but as you know not exact..that agitator coupler shown in the video bolts down under the agaitator. To remove your agaitator which locks into teh agaitator as shown just pulls off....so to remove your just grab the bottom of it and pull straight up and off of the agottaor coupler.
GENE
Sep 07, 2011 | GE Profile WPSR3120WWW
Washer overflowed after moving Load Capacity Switch from Super to reset and then to Large load?
On this model of washer you have 4 separate components that could cause overflowing. The water valve, pressure switch, pressure switch hose & the air dome. If you have to turn the water off to prevent overflowing, I would recommend replacing the water valve. If you can turn the timer off & the water stops overflowing, I would recommend checking the pressure switch, hose & air dome.
Jan 16, 2011 | GE Washing Machines
Myn washer always overflowes as it filling it wont
This is usually the pressure switch. Also you could check the water inlet valve if water is still flowing in the machine after it stops. There are free videos on testing these components at www.appliancehelponline.com/servicemanual.html
You can also punch in your model # for diagrams
Mar 18, 2010 | GE Washing Machines
Washer is filling too much and water is coming out overflow
you need to clean the pressure swith hose on the lft side of tub small rubber hose stop use in liqid soap
Jan 30, 2010 | GE Washing Machines
you need to post your model number
Mar 31, 2009 | GE WDSR2080D Top Load Washer
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Mar 15, 2009 | GE WVSR1060A Top Load Washer
Feb 19, 2009 | GE WBSR3140DW Top Load Washer
My GE washer wont stop filling with water or go to the wash cycle. my GE top load washer water will not stop and leaks out, overflows. model #GCXRPO9ODAWW.
Nov 20, 2008 | Washing Machines
GE WDSR2080D Top Load Washer Logo
78 people viewed this question
Top GE Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
