Question about Yamaha 12V Air Pump
Rear seat removal, fx yamaha jet ski, latch will not release the seat
Posted by Bill Jarrell on
Wayne Horne
    New Friend:
I have a 2007 Yamaha jet ski. I was able to use a 10mm open end wrench and remove the latch from the seat. If you look through the grab handle and under the seat you can see the post that holds the seat and in either side you can see the bolts holding the latch on. Only a small portion on the bolt head is visible so you have to be patient as there is very little room to maneuver. As you slowly, an 1/8 turn at a time, remove the 2 bolts the latch will come away from the seat. Good luck.
Posted on Jun 24, 2014
Jeff's Garage
    New Friend:
  • 118 Answers
As bad as this sounds its the only way. Grab yourself a 2x4 and a nice size prybar.
Lay 2x4 across the back grab handle as to not damage it then put prybar directly under seat latch and pop it up.
Posted on Oct 29, 2011
  • Jeff's Garage
    Jeff's Garage Oct 29, 2011
    Just to make sure its broken, you should try sitting on the seat first while trying to unlatch.
  • Jim White Jan 10, 2013
    Broken Seat Latch Handle, Does this do any damage to the seat locking mechinism?
1helpful
What now ?? my yamaha suv1200 Can the transmission be shot ?
there are no gears just a direct drive from the crank to a jet pump ! if theres no propultion of water it could be several things !
1. plastic bag etc in the intake to impellor pump assy !
2. impellor gap to housing too much ie worn impellor !
3. impellor not turning because splines on either the shaft or impellor worn !
4. drive coupler damaged and spinning on shaft !
Try running on a hose pipe and look at rear of engine ( remove plastic cover so you can see the 2part coupler and drive shaft ) .
Check the impellor assy !
Relay replace starter
if its xlt 1200 its inside the big black electric box at rear of engine ! unbolt it and remove the back cover !
Won't start
Fuses in the electrical box?
2010 Yamaha FX Crusier jet ski
sparks ? compressions 100psi or more ? water in fuel ? injecters clean ?
Jul 14, 2013 • Boating
1helpful
3answers
I have a Yamaha FX Cruiser HO (2010). The jet ski died in the water on me last week. I determined it to be a fuse. Replaced the fuse with the extra one and it burned out again. Any suggestions?
i have a 08 yamaha fx sho it keeps on freezing up in the water and dying of, i was almost 10 miles into the ocean and had to be towed by one of my fellow riders. whats causing this problem?
How to remove the seat
Bubba, Under the front of the seat is a latch that you must release there is a rubber block that must be rotated forward to be able to release the two little knobs that it is wedged between Rotate the knobs inward and lift the front of the seat. the seat will flip toward the rear of the chair and you now have access to the batteries. to remove the seat disconnect the joystick cable from the base and slide the seat forward after you have it tilte back and lift it off the base. Hope this helps you
7helpful
2answers
Overheating YAMAHA XLT 1200 jet ski
you may have something clogged in a water passage but more than likley u have a bad sensor the sensor is located on the main exhuast if you go on the right side of the ski and look in the engine compartment it will be located at 9 oclock u will see it sticking out of the exhuast with one wire comming out after u run the ski and the buzzer goes off pull the seat and see if the engine is really hot if u can not touch it will be hot but it has to be very hot for the sensor to pick it up if u can touch the motor and exhuast it is a bad sensor
5helpful
My yamaha jet-ski is in learning mode. how do i turn it off?
Its going to ask for a code!!If not lift the seat find the blue plug un hook it then hook back up it will ask for code push AAA then hold it will reset it if this is digital odomtor
1helpful
2answers
Putting the back seat down in a 97 Mazda Protege
The release on an LX or ES model is at the top of the seat backs, near the door opening, for the rear seats. The rear bench is a 60/40 split on these models. The rear seat does not lay down on the DX models.
Yamaha 12V Air Pump Logo
Top Yamaha Water Sport Experts
Mike
Oloyede Monsuru
johnny bonacci
johnny bonacci
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
