First restart your Toshiba laptop. Press either "F1," "0," or "F8" to be taken to your computer's hard
drive utility screen. The key command differs depending on the model
Toshiba computer that you own.
Select "Restore Original Factory Image" from the list of options in
System Recovery. Verify that you want to continue the process by
clicking "Yes," then click "Next".
Restart the Toshiba laptop once the factory restore process has been
completed. You will be prompted to enter information such as the date,
time and language preferences.
Feel free to get the reliable technical help at http://www.vtechsquad.com/toshiba-support/ for troubleshoot all kind of Toshiba PCs(laptop/desktop).
Feel free to get the reliable technical help at http://www.vtechsquad.com/toshiba-suppor... for troubleshoot all kind of Toshiba PCs(laptop/desktop).
Put the windows cd in, turn on laptop, boot from cd,
click on format, when it sees that there already is a copy of windows
on there do not try to repair just contine to install fresh. there you
go. good luckput the windows cd in, turn on laptop, boot from cd,
on there do not try to repair just contine to install fresh. If you have the bundled CD of XP with this laptop then it must have the
option of re-installing with format or without format ..
If you dont know how 2 use it then the simple method is to use a windows98 bootable CD.
Boot from it.
format c: at dos prompt
then install from laptop xp cdthere you
go. good luck
