Hi rossclark3,
Try to check the jumper settings of your DVD/CD ROM if it is properly assigned as Master or Slave.
Afterwards, also check the cable connecting the DVD/CD ROM to the motherboard.
Finally, restart your PC and check the BIOS Setup if it can already detect your DVD/CD ROM.
Hope this helps you a lot.
Thank you for using FixYa!
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
