Best plasma TV HDMI
Which woiuld be the most reliable 50 inch flat screen plasma 50 inch HDMI TV to buy. Least problems and lowest heat output
Posted by Michael Criswell on
Chi Chu
  • Televison & ... Master
  • 8,457 Answers
None.All Plasma tvs designs are alway have high heat output and consume alot more A/C power energy than any other tvs designs out there.Tvs like CRT-tube tvs,DLP tvs -Projection tubes and projection lamps tvs,LCD-flourescent tubes tvs as Liquid crystal display screen tvs.All these tvs designs are all good tvs designs to buy but the pictures display and screen lighting and the sharpness of the pictures never have and able to compare high enough qualities as a display picture on the screen output to a Plasma screen tvs,until now LED-tvs are LCD and LED screen display combine to make it better and brighter technologies and now are good enough to compare to a Plasma screen panel tv.So buy a LED tv will get less heat output and comsume less A/C power energy too and it is good enough pictures qualities too.To compare too as a plasma screen panel tvs output.
Posted on Oct 29, 2011
What type of inside antenna do you recomend and where do I find plug in on 60in Samsung plasma TV?
If your model number is correct, you and I are both getting too old.
This set has all modern connection (or connectivity) means but nowhere did I find a mention of a cable or antenna input, including the Samsung specs on your set.
This link will show you what you (and I) would expect to find:
connector Wikipedia the free encyclopedia
If it isn't there, you are out of the antenna business without buying still another 'box.'
Here are two, by description they will accept antenna inputs and provide HDMI output for you set; lowest cost one first:
3500STB
CM 7001
Jan 07, 2015 | Samsung Pn60e550 60" 1080p Plasma Flat...
How to hook up a panosonic 50" Flat screen plasma
Try connecting TV to DVD with a scart lead or a hdmi cable now hdmi v cables are the next best thing from a scart lead
Dec 21, 2011 | Televison & Video
I was going to get a plasma TV specifically the Samsung PN50C6500 and i was wondering if the whole thermal expansion controversy problem was over and samsung had become more reliable and this problem had...
No,don't buy plasma tvs any tvs make or tvs brand.Don't buy any kind of tvs using plasma gas as for plasma screen panel as a power sourced if u play major hours of gaming on the plasma tvs,u will still have thermal expansion problems but less.Plasma tvs still have major problems,with screen BURN IN problems though.
Aug 22, 2011 | Samsung PN50C6500 50 in HDTV Plasma TV
Yes i seem to be having a problem with my sanyo 50 inch tv.the channel's keep flickering from audo to video to hdmi , with no picture and the tv is only on for only like 3 min
- Check the remote for any stuck buttons
- The control IC or IC connection has got some problem. The best option in this case is - call the authorzied service technician.
Mar 05, 2011 | Sanyo DP50747 50 in. Plasma TV
I do not know how to work the display resolution
The tv display resolution will automatically change depends on your source/device output resolution and TV inputs used as well. Television component and HDMI inputs accept 480i up to 1080p signal while composite and s-video accepts 480i(lowest resolution) signals only. You will get high resolution signals from cablebox, game consoles, bluray etc through their component or HDMI output jacks.
Dec 25, 2009 | Sanyo DP50747 50 in. Plasma TV
Toshiba 50HP66 and HDMI problem
hi the best thing to do is call toshiba and let them know your problem
Jan 10, 2009 | Toshiba 50HP66 50 in. Plasma Television
Hd tv doesn't work at all says invalid format
is the tv 720 or 1080. it wont work if your inputing 1080p to 720p or 1080i
Dec 11, 2008 | LG 50PC1DR 50 in. Plasma HDTV
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Televison & Video Logo
200 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
