Apple iPhone 4 Black Smartphone Logo
Anonymous Posted on Oct 28, 2011
Is there a way to sync contacts on the iPhone with both Google Contacts and iCloud without creating duplicates?
Mitch
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 19 Answers
  • Posted on Oct 08, 2023
Mitch
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
19
Questions
0
Helped
748
Points
63
Yes, you can sync contacts on your iPhone with both Google Contacts and iCloud without creating duplicates by following these steps:
1. Sync Contacts with iCloud:
•Go to "Settings" on your iPhone.
•Scroll down and tap "Contacts."
•Under the "Accounts" section, tap "Add Account."
•Select "iCloud" and sign in with your iCloud credentials or create an iCloud account if you don't have one.
•Enable the "Contacts" toggle to sync your iPhone contacts with iCloud.
2. Sync Contacts with Google Contacts:
•Select "Google" and sign in with your Google account credentials.
•Enable the "Contacts" toggle to sync your iPhone contacts with Google Contacts.
3. Merge Existing Contacts:
•After syncing with both iCloud and Google, it's essential to ensure that your existing contacts are merged to avoid duplicates.
•Open the "Contacts" app on your iPhone.
•Tap "Groups" in the upper-left corner of the screen.
•Uncheck "All iCloud" and select only "All [Your Google Account Name]" and "All on My iPhone." This will display all your contacts from both iCloud and Google.
•Now, go through your contacts and manually merge any duplicates. To do this, open a contact, tap "Edit," and then scroll down to see if there are duplicate entries. If you find duplicates, you can merge them by tapping "Link Contact."
By following these steps, you can sync your iPhone contacts with both Google Contacts and iCloud while minimizing the chances of creating duplicates. However, it's essential to periodically check and manage your contacts to ensure that duplicates do not accumulate over time.
Duplicates also shouldn't be a problem - https://applenapps.com/delete-duplicate-contacts-on-iphone/ as they can be easily cleaned up.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
201
Points
Google does two things that have caused massive duplication of contacts: 1. If you have anyone with three words in their name, in other words when you combine their forename & surname, if there are more than 3 words, Google decides to put some of the names into the "middle name" field. This changes the contact enough to cause a dup. This will happen with a forename like "George W." also; 2. If you stored someone's address details using the wrong country format for that person, i.e. you used the default US format for someone who lives in Germany, then Google will switch the format for you causing another duplicate when you sync. I gave up trying to sync to both.
Anonymous
Level 1:
New Friend:
  • Contributor 57 Answers
  • Posted on Nov 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
57
Questions
0
Helped
13527
Points
87
Yep. sync your google contacts w your iphone.. then dis associate it with google. then set up icloud to sync contacts it will now use cloud to sync contacts if you have contacts allready on icloud make shure you have it their also.. duplicatles will show up and most likely wont appear...
  • Anonymous Nov 03, 2011
    But then I'm not syncing to Google anymore. I want to sync to both of them on an ongoing basis
    wait i think the iphone will sync to cloud mainly . and sync to google so your contacts arent doubled... unless its a android phone which that willl happen
2answers
A simple to implement, reliable way to sync Outlook 2016 Contacts and Calendars with my iPhone 6? (iCloud was a nightmare)
There are about 50 (at the very least) apps in app store ( I use 'Easy Backup" that would allow you to scan your contacts on iphone and email backup file so you can import it (one way sync) to either Outlook or Icloud.
2answers
Sync Contacts in Address Book from computer to iPHone.
On your iPhone, make sure that
  • in the Settings app
    • Mail, Contacts...-->iCloud has Contacts enabled (green button)
On your Mac, make sure that
  • System Preferences-->iCloud has Contacts checked.
If the iPhone still doesn't sync,
  • connect the USB cable from the iPhone to the Mac,
  • open iTunes,
  • make sure that "automatically sync iPhone when connected" is checked in the Summary window of your iPhone (in iTunes);
  • and click "sync" in the lower right corner of your iTunes window.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
2answers
How to sync iPad to macbook pro
just istall iTunes software from Apple and plug the iPad connector cable to an USB plug on the macbook.
then turn the ipad on and start iTunes - you will see your iPad in the middle on the left side of the screen - then it prompts you to sync
Apple iTunes Download iTunes Now Apple iTunes Download iTunes Now sync-ipad-macbook-pro-z4ipswfycprf0ccft4hwg0fn-2-0_0.jpg sync-ipad-macbook-pro-z4ipswfycprf0ccft4hwg0fn-2-2_0.jpg Sync your iPhone iPad and iPod with iTunes using USB
Restore iphone contacts
If you have synced your iPhone XS Max to iCloud, it would be easier for you to retrieve deleted contacts from iCloud for iPhone XS Max and other iPhone models. The below steps would show you how to restore contacts you have deleted from iPhone XS Max from iCloud for your iPhone XS Max and other iPhone models.
1.On your computer, open icloud.com and log in with your Apple ID account.
2.Go to Settings tab on iCloud.com, then click "Restore Contacts" (in the Advanced section).
3.Then, you will see available versions listed by the date and time they were archived previously.
4.To the right of the version you want to restore, click Restore option.
5.Wait until iCloud finishes restoring your contacts before you change them. While it's restoring them, any changes you make aren't saved.
The restored contacts and contact groups will appear on all your devices set up for iCloud Contacts. If you haven't set up your iPhone XS Max for iCloud, on your iPhone XS Max, go to Settings > [your name] > iCloud, swipe Contacts option to green on the "iCloud" window, and then click "Merge" button. You could then view all restored contacts on your iPhone XS Max.
Actually, with iCloud, you can restore your contacts, calendars and reminders, or Safari bookmarks and reading list from an earlier version that was automatically archived in iCloud. However, restoring contacts for iPhone XS Max and other iPhone models requires you to have archived contacts to iCloud.com previously. Otherwise you won't be able to retrieve contacts from iCloud.com.
For more methods, check: How to Recover Contacts from iPhone XS Max/XS/X
2helpful
3answers
How to transfer Contacts in iPhone to Outlook
Once your iPhone is connected to your PC and iTunes is loaded you can right click on your iPhone and select exactly what you want to have sync'd.
1. Under the Info tab you will find Contacts. 2. Tick the "Sync contacts with :" and select Outlook from the list. 3. Click "All contacts"
If you wish to put all of your iPhone created contacts into a different group in Outlook you can select the group there also and tick the relevant box.
iTunes always displays a warning about over writing data but that is not relevant to Contacts. Data is always merged.
I hope this solves your problem.
Chris
2answers
How do I synch outlook 2003 with iphone
You didn't say whether you're trying to sync everything (mail, calendars, contacts) or just some things or one thing (like contacts only). I don't know if you're using an Exchange server or even if you have the info you'll need to sync with an Exchange server.
I have a Windows mobile device (AT&T Tilt) running Outlook 2007 and everything is sync'd. We also started purchasing the iphone for our employees and sync their email, calendar and contacts to their phone.
I could probably give you step-by-step information (based on how I do this for my users at work) if I knew whether you'll use iTunes to do this or Exchange Active Sync and what you want to sync between your phone and outlook. One method (iTunes) will only update your data between Otulook and the phone when you connect it to the computer with Outlook configured on it but, the way we do it at work, they receive email, data, changes, etc in real time.
Try using this link http://www.apple.com/support/iphone/mail/
What you will find here is support topics and instructions for Exchange Active Sync, setting up email accounts, troubleshooting for contact and calendar syncing.
You can also search support on Apple's Web site. Entering the keywords: iphone outlook 2003 will bring up a lot of support info.
You can use iTunes or MobileMe for synchronization. If using iTunes then try this:
You can configure which items are synchronized during a one time set up process. After initial set up, each time you connect the iphone to your computer, the changes made on your computer or device are synchronized.
  1. Connect your iPhone to your computer. iTunes should open automatically.
  2. In iTunes, in the source list, under Devices, click the entry for your iPhone.
  3. Click the Info tab.
  4. Select which items you would like to sync. For example to sync only calendars, under Calendars, you would click Sync calendars from, and then click Outlook.
  5. Do one of the following:
  • To synch all calendars, click All Calendars.
  • To limit the calendars that are synched, click Selected calendars and then click the calendars you want to sync.
6. Click Apply.
Hope this helps!
Thanks for using Fixya and you can let me know how helpful I've been by rating this solution.
1helpful
2answers
How to delete all contacts
if you want to delte all your contacts you can do it either by synce with itunes or you can erase all data on your iphone total by going to settings then general then reset then click on erase all content and settings, warning this will erase eveything games, music all files.
2helpful
4answers
Sync Outlook Contacts & iPhone
When you create a new Contacts Folder you have to make sure that you create as a subfolder of the main contacts folder (in the create window you are shown the file tree).
I had the folders moved in different groups as well but I am not sure that it made a difference.
Please note that you have to leave outlook and itunes on for a few minutes before they synch and iTunes see the new folders.
Oscar
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
