Question about RCA D61W20 61" Rear Projection Television
RCA D61W20 antenna/cable broke off - RCA D61W20 61" Rear Projection Television
Posted by Angela Bettis on
SD Tech
    Top Expert:
  • RCA Master
  • 14,553 Answers
You have two real options here.
First any good shop can remove the board and repair/replace the fitting but it will not be cheap.
Figure 150 minimum for this on this set.
Second: If you have a cable or sat or other box for signal and it has AV jacks on the back---go from them to one of the inputs on the back of the set and BYPASS the tuner connection.
If you do not have a box but have an old VCR around (it does not have to work) you can connect the signal source to it and from its output (audio/video not the coax) route signal to the set.
Does this make sense or do you have questions?
sd tech
Posted on Oct 28, 2011
Manual rca D61w20
Hello
Get into this site. You can download the user manual for your RCA D61W20 HDTV from here for absolutely free. It is in PDF format. If you feel any difficulty in downloading the same, send your Email ID to me by Fixya. I've the downloaded manual for your TV, and I'll send a copy of it to you by return mail. OK>
Oct 14, 2011 | RCA D61W20 61" Rear Projection Television
The coaxial cable antenna broke on my RCA tv
The part is called a Female Belling-Lee Socket. Radio Shack, or anywhere that sells antennas, CB radios, repairs TV sets, should have one. Soldering it in, is another matter. Be careful.
Feb 04, 2010 | RCA Scenium D40W20 40" Rear Projection...
Trouble turning on RCA D61W20
the green light blinks three times but does not come on
Aug 16, 2009 | RCA D61W20 61" Rear Projection Television
RCA HDTV #D61W20, CHASSIS ITC222, PUSH & TWIST CAP ON HV CABLE
do you have the part number for the flyback ? I need it if you would please. send it to
[email protected]
thank you
Apr 01, 2009 | RCA D61W20 61" Rear Projection Television
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
Cable plug broke off
Well first repair the coaxial cable going to your antenna. There is no way you can use RCA cables as a substitution for coaxial cable. They have totally two different properties. You can use the coaxial and feed it to a VCR/DVD player where you can output the signal with RCA/composite cables. Basically, use your VCR/DVD player as a tuner for your TV.
Sep 20, 2008 | RCA D56W20 56" Rear Projection Television
RCA Model D61W20 - cable plug came out
go into vcr then use rca inputs to tv . the cable sockets are usualy pretty easy to replace .take out old part and might even find replacement at local radio shack.
Mar 12, 2008 | Televison & Video
RCA D61W20 61" Rear Projection Television Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
