Question about HP Compaq Presario CQ50-110US Laptop
How do i turn on webcam on compac cq60 - HP Compaq Presario CQ50-110US Laptop
Posted by john lan on
Brian Sullivan
  • HP Master
  • 27,725 Answers
Click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools computer management device manager scroll down image devices you could see a yellow question / exclamation mark ? ! or a red X
right click to reinstall drivers or update driver
http://www.filebuzz.com/findsoftware/Universal_Software_For_All_Webcams/1.html
http://www.filebuzz.com/findsoftware/Webcam_Driver_For_All_Webcams/1.html
also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
hope this helps you
Posted on Oct 28, 2011
  • HP Master
  • 17,130 Answers
If the web cam is installed and the icon is on the desktop then all you need is to click this icon. However if the icon is not placed on the desktop you must open the menu and check for programs , if the webcam is seen to be installed then you can right click and send the icon to the desktop. If not the webcam is not installed and you need to download the drivers from the compaq website , install and run.
check this link:
http://www.compaq.com/cpq-country/cpq_support.html
3 Related Answers
Anonymous
  • 1383 Answers
SOURCE: the drivers of window compac presario cq60 104tu XP professional
select your model from here and downlaod
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-001&h_lang=en&h_cc=us&h_product=89327&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us
Posted on Apr 24, 2009
Anonymous
  • 59 Answers
SOURCE: I have a compac CQ60 and the webcam has just
Its a geniune problem with HP & Compaq Notebooks with Webcam
At first you need to check whether the Webcam is working through the application sent from Hp's end or not.
For example CYBERLINK YOUCAM or HP MEDIASMART is the name of the application which Hp sents.
If the Webcam still doesn't work through the application sent from Hp's End.
Then Click on START and in start search or run type DEVMGMT.MSC
It would take us to the device manager page.
Locate something which reads as Imaging Devices.
CLick on the + Sign next to it and then right click on the driver that come under IMAGING DEVICES and then click on UNINSTALL.
Now look at the top of the device manager window and locate ACTION TAB,click on ACTION and then CLICK ON SCAN FOR HARDWARE CHANGES.
Now check whether the Webcam starts working in SKYPE or MEDISMART or CYBERLINK YOUCAM.
Now if you dont find imaging devices in device manager then uninstall CYBERLINK YOUCAM or HP MEDIASMART from programs and features and reinstall the same through RECOVERY MANAGER or from the manufacturers Website.
I am providing a link for reinstalling CYBERLINK YOUCAM
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=ob-68857-1&jumpid=reg_R1002_USEN
Posted on Mar 19, 2010
Anonymous
  • 45 Answers
Sorry. Download the webcam driver from hp.com/support and reinstall it. That should work.
Posted on May 13, 2010
I have a compac presario cq60. when i turn on the computer the there is a blinking line in the top left corner. the computer does not come on.
Hmmm,
Ok, well if your machine shows the manufacturer logo (Compaq) and then goes to the blinking light there is usual and issue with either the hard drive (hardware) or the installed operating system (software). If the cursor is blinking before the logo this is usually an bad component (most likely ram or motherboard) causing the machine not to turn on correctly.
All of these issues need professional help, if not under warranty I would bring this to my local shop to be looked at.
Mar 15, 2011 | Compaq Presario CQ60-220US PC Laptop
Have a compaq cq60 turned it on and have a black screen with compac on it and it wont do anything else
It looks like your hard drive has failed, you could try booting with you rescue disk or any bootable disks which can be dowloaded for free
a) Ultimate boot disk for windows (Diagnotic software)
b) Ubuntu (Alternative operating system) Just "try ubuntu" don't install, well not at first.
Both will boot your computer with an operating system, you'll be able to check you HDD, you may also be able to retrieve data.
Nov 13, 2010 | Compaq Presario CQ60-220US PC Laptop
How do i turn on my webcam because i wanna talk to my friends from my webcam on my laptop CompaqPresario CQ60 and i dont know about webcams??
hello
if you dont have one already, you need to download a program from YAHOO, MSN, SKYPE, or any other video direct program that allows you to communicate using the webcam. if you need to know how to adjust and operate the webcam, see link below
http://h10032.www1.hp.com/ctg/Manual/c01530857.pdf
i hope this helps you
Oct 27, 2010 | Compaq Presario CQ60-220US PC Laptop
I have a compac presario cq60 with a blank screen. Screen went blank 2days ago. Need help please!
Without more information i would have to say that your inverter has died. The inverter provides light for your screen.
Oct 25, 2010 | Compaq Presario CQ60-204NR Notebook
Webcam not working om compaq presario cq60
try installing the driver and verify the driver has been installed properlly
Oct 30, 2009 | Compaq Presario CQ60-220US PC Laptop
Touch pad not working correctly.
have you just installed some new software if so it is confliting with your touch pad unistall the new software and see if it works if not try unistalling the drivers and re install .....
Oct 09, 2009 | Compaq Presario CQ60-220US PC Laptop
Webcam not working. how to turn it on from keyboard.
double click on mycomputer and in mycomuter u will see the webcam icon double click onit and it will work.
Apr 25, 2009 | Compaq Presario CQ60-220US PC Laptop
HP Compaq Presario CQ50-110US Laptop Logo
90 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
