Samsung SyncMaster 740N 17" LCD Monitor Logo
Question about Samsung SyncMaster 740N 17" LCD Monitor
I want power supply circuit diagram for samsung 740n lcd monitor
Anonymous
  • 2,574 Answers
Samsung SyncMaster 740N LCD Monitor
Click the link below to download the Schematic diagrams:
http://manuals.xtreemhost.com/dw/samsung_740n_SCH.pdf
Note: PDF manuals require the Adobe Acrobat Reader for viewing and printing.http://get.adobe.com/reader/
Posted on Oct 28, 2011
  • 1 more comment
  • Anonymous Apr 28, 2012
    good day sir. the link you have shared above cannot be accessed , do you have any other link aside from the above site that you have posted..
    Good day and God Bless.
    or email me at [email protected]
    tnx
    here is a new link to your schematichttps://docs.google.com/open?id=0B2k3lGP...
  • Anonymous Apr 07, 2013
    thank you so much !
Transformer circuit diagram L9ZA-A1
http://www.eserviceinfo.com/index.php?what=search2&searchstring=fujitsu+siemens+L9ZA+lcd+monitor
Samsung LCD monitor Model 740N no display.
pls chek 1000/25cap ,and inverter fuse, and 5402 ics
My samsung syncmaster 740n turns on but is completely black but you can faintly see the dektop background. what should i do?
The backlight inverter circuits are not working, can be caused by bad DC filter caps in the power supply, failed inverter circuits, bad lamps assemblies.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SyncMaster 740N 17" LCD Monitor: I have two of the SyncMaster 740N's as security mo...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
My samsung sync maste 740n lcd monitor is not getting on properly.. its getting on very late..i.e after 30min i need a solution for this... plz help me... venkat 09866046610
LCD Samsung Syncmaster 740n 17... Fuse F301 is brocken.
You still have shorted out components on the circuit board, you will need to download tha service manul here to do an indepth troubleshooting: http://elektrotanya.com/
LED POWER ONLY LIFE, SCREEN DISPLAY DARKNESS
theres only one solution to the problem you have to replace the whole power supply board .its easier to replace them than finding and soldiering the defective parts like the capacitor on the board .u can just replace the power supply board if u think the power has a problem. if it doesnt work then u have to replace also the main board or the board connecting the rgb cable.its more expensive to replace the board but its worth it. ur lcd will work better and its easy to put them on the lcd casing .
1helpful
Syncmaster 740 power supply problem
I would check all the transistors (especially the larger ones) for shorts. If you can separate the power supply from the other circuits (such as by unplugging a connector to other boards), I would do this and see if the fuse still blows. If it doesn't, then the trouble is in another area, perhaps the LCD driver circuits.
1helpful
3answers
Samsubg Monitor flickers
My samsung 740N lcd Monitor is flickering. can i get a solution of this problem?
Top Samsung Computers & Internet Experts
Marvin
Marvin
Fix It Fast...
Fix It Fast...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
