SOURCE: Hi, I have AsusVW222U 22 inch
Takeout the powercord at the back of the monitor and wait 5m.
Put it back.
This fixed it for me.
SOURCE: I have a dark blue rectangle on my 26" monitor
Make and Modle number will help so we do some research on it.
It looks like you have turn on the PIP (Picture-In-Picture) function.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Testimonial: "Presto Perfect! Dark blue rectangle is now gone. Mille grazi!"
Shine
a flashlight on the dark screen to see if you barely see the icons on the
desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If the video shows on the
external monitor that proves your video card is ok, ,but your lcd screen is
bad. The video will show on most systems when you reboot without you having to
do anything. Some systems will require you to hit the FN (Function key) + F1
thru F12. Hold down the FN key then hit the correct key for displaying on
the monitor (F1 thru F12). The correct key will normally have CRT/LCD on
it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
