I have a 7863 with an era g320. can you still use the aux function and how do you plug a device in
My 7863 is in ai net mode with the era g320 hooked via ainet cable. I wish to add a satellite receiver to the aux function if possible. where do you plug in at if it is possible
On the ai net cable identify and separate strand with green, blue and unshielded common/ground. G and B will be your positive which you will then solder to red and white leads from rca or headphone cable with unshielded from that cable twisted together and soldered together with the unshielded wire from ai net cable. Tape off or heat shrink the rest of wires from ai net cable.
The source/power button in the top left corner changes the mode. Press the button until the aux appears. The auxillary device must be plugged in to register on the stereo.
ai net is simply alpine's upper level line of decks. they have their regular line and ai net line. just like kenwood has their normal line and their upper level excelon line. ai net uses different cables to connect with changers and aux items than the regular line.
Setting the AUX Mode (V-Link)
AUX IN ON / AUX IN OFF (Initial setting)
You can input TV/video sound by connecting an optional Ai-NET/
RCA Interface cable (KCA-121B) or Versatile Link Terminal (KCA-
410C) to this component.
You can change the AUX name display when AUX ON is set. Select
the AUX name by pressing g or f. Then press BAND.
If the KCA-410C is connected, it is possible to select two AUX
names.
• Via KCA-410C, up to 2 external devices with RCA output can be
connected. In this case, press SOURCE/POWER to select AUX
mode and then press BAND to select your desired device.
you need to buy a AI net connetor that goes in the thing that looks like a CD changer connection. Then you should have an input, by the way you dont want an aux output if you want to hook up an iPOD you want an INPUT
