Question about Mitsubishi WS-55819 55" Rear Projection Television
My panasonic cinemavision 1081 wont turn on the power button just flashes
Posted by preston and angela... on
SD Tech
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Model number please? Also count the number of blinks: 3 or 5 or?
SD TECH
Posted on Oct 28, 2011
  • Dawn Klubben Jul 25, 2013
    model number pt-47x54 J IT BLINKS 3 TIMES
My TV wont turn on. If I unplug it and then plug it back it and press the on button, it clicks like its going to turn on but then clicks back off. Is it dead?
Most likely the power supply board has failed.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Nov 27, 2016 | Televison & Video
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
When turning on my panasonic cinemavision tv, it makes a click sound then the power button light flashes red three times, no picture comes on the screen, any ideas what should be done?
Have you replaced or checked all the fuses? Do that first, then if you still are having problems, email me back. I will send you replacement parts, very cheap, and will tell you how to install. hill6399 at yahoo
Feb 27, 2010 | Toshiba TP55H60 55" Rear Projection...
There is no picture. When it is turned on the
the convergence circuits have failed. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the parts and the Cd with instructions
Jan 15, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Replaced convergence chips, have new problem
Did you check the 2.2 ohm 2watt resistors? As often one or two will blow when the old ICs fail. The 3 blink error is indicating a problem with the convergence circuit still.
Jun 19, 2009 | Panasonic PT-47WX49 47" Rear Projection...
My Panasonic CinemaVision 47" won't turn on.
Thats the error for the convergence. The following repair kit will usually repair that. The kit contains the parts and instructions with pictures on how to do the repair. Heres a link to the kit for your model. http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
May 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Most likely a power supply failure although the flashing of the LED a fixed number of times may point to something else such as a lamp failure. If you can find a forum for this series, you may find a Panasonic tech who can give you a better read on this.
Feb 18, 2009 | Toshiba TP55H60 55" Rear Projection...
Helpme
Replace Both of your convergence ICs they are big black ics STK392-110? use 180s .
Dec 14, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53WX53 cinemavision HDTV keeps powering off right away
5 blinks is telling you that IC4511 on the DG board is faulty. This is not serviceable you will need a new DG board the part number of that board is TNP2AA126
Mar 25, 2008 | Televison & Video
Mitsubishi WS-55819 55" Rear Projection Television Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
