Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
Friends of yoho Posted on Oct 27, 2011
We have a combo tel/fax line. We can receive faxes if someone is in the office and answers the phone, but if we don't pick up the phone it goes directly to the answering machine..
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Oct 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
496
Points
12
You need to configure your fax machine to act the way you want it to. instructions will be in the owners mmanual ..
We have two fax machines hook up to one dedicated fax line. When we send a fax from wither machine it is not faxing to the phone we fax it only sends the fax for the second fax machine that is in our...
Yes, you must set up your fax machines like this: The receiving fax must be set to auto receive and the telephone line must be inserted in the "line" input. A line must then be connected from the "Tel" to the "Line" of the Transmitting machine, which must be set to "manual receive." This is not really a satisfactory way of doing things as you can't send and receive 2 machines on the same line together. A much better way is to have 2 lines. with a machine attached to each. Get the tel company to put "No answer transfer" on the line as an accesory. Give them the number of the fax machine that transmits. Make it "manual receive" Now you have a versatile system that you can also use the office telephone with.
I have a PIXMA MX850 printer. The system was preset to fax priority mode so I had to keep the printer off to use my phone line which is 99% voice and 1% fax. I have now configured the printer to TEL...
It will only automatically pick up the line when set to "fax". You need to subscribe to a "distinctive" ring (which is a double ring) service through your telephone company and set the rings to answer appropriately so as to not conflict with your voicemail
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Cannot receive auto faxes
This is a known problem with the MX850 - Canon thinks it works, but it needs to be FAX Only when you're out of the office and TEL PRIORITY when you're in the office - then you hit "Hook" when you hear an incoming call as a fax tone. It's a manual answer machine when in TELEPHONE Priority
Receiving and sending faxes
if the fax is connected to the same line and you have a phone connected to the fax you need to make sure you connect the line from the socket at wall to the correct socket on the fax you can check this by looking at the point the line is connected on fax there should be two connectors one says line and one says tel.. the line in goes to the line socket and your telephone goes into the tel socket.. if you have them the other way round it cant connect properly..on the front display panel make sure you have it set to the auto setting or tel fax mode for receive.. if you have it to auto it will check the incoming call if it is a fax it will send it through if not it will ring till you answer.. if set to tel/fax mode when it rings you will have to answer the phone and manually press start if you hear it is a fax.. Good luck A
4helpful
2answers
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
VOICE MAIL AND FAX
The short answer is no. The JX200 will work with an answering machine because it "listens in" when the answering machine picks up a call. It can't "listen in" to voice mail, because the voice mail is handled by your phone service.
Fax & Phone sharing the same line
I am not really familiar with your machine, but have worked on faxes for 20 years. Most models are fax, fax/tel, and tel, meaning it is either or, or a combination. The function you seek was on many models with a built in answering machine. As the machine answered, you said in your message to press start now, or leave a message.
I would say, use your *9* solution with phone while you are there, but switch it to fax mode when you leave. Any regular call coming in at that time will not get answered anyway, but faxes would automatically be received. I know it is an extra step, but that would work.
MP730 fax issue-can't receive fax, but can send out
I think I know why. You need to set the proper priority of your all-in-one Canon device.
If it is TEL priority, it means you need to have a phone connected to the fax. If the phone rings, you need to pick up the handset and check if it's a fax tone or a call. If it is fax tone, you wait for 5 secs til fax tone stops, and then hang up. After that you will receive the fax. Failure to pick up the handset will not allow you to receive the fax. This might be the most probable setting you have, hence you can't receive the fax.
If it is FAX priority, the same thing happens as TEL priority. Only difference is if you don't pick up, and it is a fax, it will still receive.
You can also do FAX only. No need to connect a phone. Device will receive automatically.
-Acieboy
Machine dials during phone calls
please check if the machine is set to correct answering mode i.e. TAD/FAX ?correct it if otherwise. in case it is ok please check whether the DRPD mode may not be switched off ,pls correct it.. HAPPY FAXING HEMANT GROVER
Norman Weimar
Norman Weimar
k24674
