Question about Nextar P7 GPS Receiver
Nextar mn 2707 reset button location - Nextar P7 GPS Receiver
Posted by Mike Chaulk on
1 Related Answer
Anonymous
SOURCE: GPS Nextar MN 2707
download upgrade and gps is now showing US maping instead of canadian maps how do i revese this.
Posted on May 13, 2008
I want to reset my nextar gps passscode.
You simply need to locate the little reset button and press that for a few seconds, this will reset the unit back to factory fresh. Your user manual is below.
http://www.nextar.com/frontend/proddetail.asp?pn=X3-03&co=10000312
http://www.manualowl.com/p/Nextar/X3-03/Manual/28073
Jul 05, 2011 | Nextar X3-03 Car GPS Receiver
Need download drive for nextar x3-08
There is not a driver available to download for this gps. You may try a hard reset which involves pressing the reset button located on the back or bottom with the tip of a paperclip for ten seconds. Otherwise the hardware or software may be corrupted and you will either need to return the unit for exchange or repair to the retail location from which you purchased it or contack nextar customer service to see how they can help you.
Mar 10, 2011 | Nextar X3 GPS Receiver
I need to get information on reboot Nextar M3-03
  1. There is a reset button at the back, try to reset the device by holding in the Reset button for 10 seconds or more.
  2. If this doesn't fix the problem, you will need to send the device in for a software reinstallation or internal board replacement. Here is the Support Site from Nextar: http://www.nextar.com/frontend/contact.asp
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 28, 2011 | GPS
I can not unfreeze my Nextar GPS. I used the reset button but it won't reset.
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further
Aug 17, 2010 | Nextar GPS
My nextar x3-01 will not turn on....can you help?
Hi.
The only thing you can do is attempting reset.
If that does not work, contact Nextar.
here reset instructions from manufacturer website:
Hi.
I quote from Nextar support:
"Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact Technical Support at 888-849-0846, if the problem cannot be resolved instructions as well as a Return Authorization will be issued for your defective product. No product will be accepted without prior authorization."
Jan 08, 2010 | Nextar X3 GPS Receiver
My x3t is frozen at logon screen help
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In this case you must return the unit for exchange or repair to the retail location from which you purchased it, or contact Nextar for further assistance.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Please remember to rate my answer. Thanks.
Jul 02, 2009 | Nextar X3-02 GPS Receiver
Restting nextar q4-4
resetting the Q4-04 , direct from Nextar FAQ's >
nextar q4-04 manuals and faq's
see if that works for you , straight from the manufacturer .
if you need more help , just ask .
J5
Jan 19, 2009 | Nextar Q4-04 Car GPS Receiver
MY NEXTAR MA9336A1S IS STUCK ON THE NEXTAR SCREEN
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Apr 06, 2008 | Nextar MA933A MP3 Player
GPS Nextar MN 2707
Apr 02, 2008 | Nextar P7 GPS Receiver
When I turn on my GPS a white screen over a blue screen comes up which never used to happen
tap right hand lower corner of screen to get it to continue loading. I then upgraded the firmware to the P7 and I no longer have any problems with the unit... and it runs faster.
Oct 17, 2007 | Nextar P7 GPS Receiver
Nextar P7 GPS Receiver Logo
142 people viewed this question
Top Nextar GPS Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Nextar GPS Expert? Answer questions, earn points and help others
