Refrigerators Logo
john stoich Posted on Jul 29, 2017
My engel 43qt.wont freeze any more. It comes on when using the 110v plug but won't even get cold. Does it require refrigerant replacement like a car? also when pluged directly into my 12v lighter socket thecompressor won't even come on. Plug fuse is good. If i plug the 110v into and inverter and then plu the inverter into my lighter the compressor comes on but just won't get cold. Can you help?g
1 Related Answer
Anonymous
  • 4793 Answers
  • Posted on Feb 11, 2010
SOURCE: engel 43 qt fridge freezer stopped cooling.
have you checked the compressorpump is getting warm(a sure sign its working.sometimes a little tap works)
ENGEL STILL GETS COLD BUT RUNS VERY HOT AND USES MORE POWER
FRIDGE COILS SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
My Emerson ice maker, will make the 1st round of 9 ice cubes, then it fills back up with water and makes a clicking noise and won't freeze anymore cubes I'm so sad, I don't have money to buy a...
If it won't freeze the cubes that because the freezer section is not cold enough to freeze them. the ice maker itself dose not have any cooling in it. it all comes from the freezer. sounds to me like there may be a problem with the ice maker and it may need to be replaced.
Zdis15
check hot gas valve to make sure it is not bypassing when in freeze mode this will not let the evaporator plate get cold enough. need to check refrigerant pressers.
Refrigerator-freezer won't freeze
I think the fridge is low on gas, or the defroster is on all the time
My old Engel won't work on 12v but it runs fine
By the way , What is a Engel? New or old? Desktop or laptop?
2helpful
GR-349SQF won't freeze
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
R
My refrigerator won't freeze or cool
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
My refrigerator is model# RT21LMXKQO5 so I am hoping that the answer will be the same for this . It will freeze and cool fine but it won't come on and run every time. We can turn the thermostat...
NOTE: This
Leo Ponder
4helpful
35 litre Engel. Not getting cold.
can you feel if the fan is blowing air
Top Engel Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Jorgie  the...
Jorgie the...
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
