The bottom oven wont heat up and light not lit but top oven and hob working fine. anyone had this problem? only had the cooker 18 months.
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
Paul is from the Naturally he would appreciate beer How to Repair Home...
2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Not a solution.. but the same has happened to my DVC5622x and it's only 13.5 months old. I also noticed someone else with the same problem on this site..posted problem end of Aug.. I wonder if this cooker has a manufacturers fault?
For what it's worth... I contact Beko and suggested to them that this product was not fit for purpose and not of reasonable quality... they replied.. after proof of purchase that .. and I quote..... "We are able to offer our customers a free of charge repair as a gesture of goodwill on appliances up to 3 months outside the manufacturing warranty, providing we receive a copy of receipt".... don't if that helps....
Mine turned out to be an internal overheat thermostat.... which was a one shot thermostat..... the engineer did mention that some models had upgraded ones.. and that he'd move it to a better place within the cooker......
