Question about SVP PS9700 Film Scanner
I have a qpix PS970 scanner, only 3 mths old. The Small USB outlet where the power lead plugs into in the front of the scanner has just broken away from its place and is now rattling away around the inside of the scanner. Is there a way to open it to retrieve and re-position the fitting?
Posted by mary shields on
tony_cassoz
    New Friend:
Just purchased a Qpix PS970 scanner and no instructions can you help?
Posted on Apr 09, 2013
1 Related Answer
Jim Thomson
  • 1099 Answers
SOURCE: i bought a qpix PS970 scanner. it is only 3 months
If this is a manufacturing fault as opposed to accidental damage you should be able to obtain an exchange or repair if you return it to the shop you bought it from. Hope this helps.
Posted on Nov 28, 2011
How do I use my PS970 Film and photo scanner?.
I didn't find a manual but I did find the customer care site. Maybe they will help you.
News Events Digital camcorders and high definition mini camcorders from...
Oct 05, 2014 | Watches
I bought a qpix PS970 scanner. it is only 3 months old. The front input for the power lead has disappeared inside the machine. How can I open it up to retrieve and reposition it?
Oct 27, 2011 | SVP PS9700 Film Scanner
When I start up my computer, nothing happens. The hard drive doesn?t spin, the fans don?t work, nor do I get any display. I?ve checked the power strip and know that power is getting to the computer, but...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 06, 2010 | Computers & Internet
Check error
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Nov 29, 2010 | Brother M 4318 Matrix Printer
I have 2 Epson V500 Scanners, 1 of them I just have on standby. The one I use daily does not turn on. I tried using the cables of the standby unit already. I checked the fuses on the plugs of both...
  1. Check that the power socket switch is on Make sure your scanner's power cord is securely connected to the scanner and a working electrical outlet.
  2. If your scanner is supplied with a power adapter, make sure your scanner's AC adapter is securely connected to the scanner and a working electrical outlet.
  3. Make sure that the power outlet works. (If necessary, test it by plugging in another electrical device and turning it on.)
  4. Check that the power switch is on at the mains socket. If this is on, carefully check the power cable to ensure it is not damaged and remove then reseat it before attempting to turn the scanner on again. If your scanner has a power button, make sure that the button is depressed so it is turned on. Also, make sure that your outlet works and is not controlled by a wall switch or timer.
  5. Power off the scanner at the mains socket. Unplug the power cable from the socket, then remove and reseat the power cable from the scanner's power cable port. Plug the scanner back in at the mains and ensure the socket is switched on.
  6. If your scanner has a power button, does the power button depress when pressed? Press down firmly on the power button, if it is stiff and does not depress then there may be a problem with the button.
  7. Connect the scanner directly to the mains - not via a surge protector or extension lead. If your unit is connected via a surge protector or a power strip/extension lead, connect the unit directly to the mains socket.
  8. Try another suitable power cable. Check that other electronic devices connected to same power socket have power and try another mains socket and another power cable if necessary. Failing this try another suitable and known-working power cable. Depending on your scanner, a standard "kettle lead" or "figure of eight" power cable is used. If there is power to the scanner (indicated by an illuminated Start light), when a different power cable is used, then the fault is with the original power cable.
If the unit does not power on after following the checks above, contact Epson for support. If your scanner uses an AC adapter, then this may need to be replaced. If your scanner is over 12 months old, you can purchase a replacement AC adapter directly from Epson.
Nov 13, 2010 | Epson Perfection V500 Flatbed Scanner
I cannot get the computer to recognise the Maxtor device. I had it working 18 mths ago and have now just reconnected it. Not sure if I have all things plugged in correctly but can't find a diagram of...
The correct lead should be Y shaped and two of the limbs plug into two USB sockets on the PC, the third lead has a small jack which goes into the OneTouch. It should light up if it is getting power from the USB and there should be an icon showing for it in My Computer.
Aug 17, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
How do i connect the speakers to my computer?
Step 1 Connect the green connector
from the subwoofer into the green jack on the computer
(the black connector is not used)
Step 2 Plug the orange connector from the right/control satellite into the orange jack on the subwoofer.
Step 3 Plug the brown connector from the left satellite into the brown jack on the subwoofer.
Step 4 Plug the AC plug into the wall outlet.
Step 5 Turn on the speaker set and adjust the volume accordingly.
Jan 22, 2010 | Harman Kardon HK695 Computer Speakers
I am trying to reinstall HP Scanjet 5400c but it keeps telling me it can't initialize, no scanner recognized...WindowsXP.. it worked before, why not now?
I had similar problem with my UMAX scanner on numerous occasions. I now have this pg earmarked for quick reference! may help I don't know for sure but it is an easy test and if it works your good to go!
It is important that you connect the scanner's power and USB cables in the following order:
1. Plug the power adapter cord into the scanner and into an outlet. The scanner's power will then be on.
2. Connect the USB cable to the USB port on the
back or front of the computer.
NOTE: If you unplug the scanner's power ,you must also disconnect the USB cable from the computer. To resume use of the scanner, remove the power card, the the USB cable.
Sounds like a lot but the order is essential!
If it works, High lite Do unplug USB/unplug cable back of scanner/and plug cable back of scanner then USB!
Good Luck Hope this helps!
Mar 26, 2009 | HP ScanJet 5300C Flatbed Scanner
Scanner
THE PROPER WAY ON INSTALLING USB DEVICES A. Enable usb ports on the BIOS. 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Sep 21, 2007 | Microtek ScanMaker 4900 Flatbed Scanner
SVP PS9700 Film Scanner Logo
408 people viewed this question
Top SVP Office Equipment & Supplies Experts
Marvin
Marvin
Are you a SVP Office Equipment and Supply Expert? Answer questions, earn points and help others
