The Aspire One is a netbook produced by
Acer; it does not come equipped with a CD ROM drive, so a traditional
hard drive reformat and Windows reinstallation is not possible without a
peripheral storage device. An external USB CD or flash drive will suffice, however.Difficulty:Moderate Instructions
Unlike
other laptops, Acer laptops integrate a computer management utility
called 'Acer eRecovery Management' to create backup of hard drive data,
create restore point, reinstall applications & drivers, and reset
Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to
reset your Acer laptop. This process will erase all data from your hard
disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
Any other issue with Acer laptop/desktop, get technical assistance at http://www.vtechsquad.com/acer-support/
SOURCE: Aspire L310 Desktop: can acer aspire L310 desktop work with win xp and ...
Yes. I am currently updating an Acer Aspire L310 (lunchbox format) desktop.
Many of the drivers are contained on the XP installation disk and will automatically be installed when you install XP.
Other Drivers:
Assuming your L310 has the same hardware (may not), you can use the following Hardware detail to locate the drivers by typing in the hardware model into a search engine like Bing.
NIC - Marvell Yukon 88e8056 PCI-e GB; this driver can be downloaded from www.cnet.com. On this website, just type in the model info and it will direct you to the driver download.
Wireless NIC - Broadcom 802.11g; download from www.cnet.com
Display/motherboard chipset - Once you have installed XP and the NIC driver, go to www.intel.com and click on the "downloads/support" option. The website provides an autodetect utility that will identify your hardware and provide updated drivers.
Audio - go to Realtek website and select "downloads". Download/install the high definition audio driver for XP.
Once you are up and running with XP, run the Microsoft Windows Update utility and it will find updates for many of the essential drivers.
...hope this info helps
