This old PC has CCFL lamps and most are dead now, for just that reason. 2008 PC>? 2 year before first PC had LED back lamps. not photo of your screen messing up, so no ACCURATE ANSWERS possible. this line is it 1 pixel tall? or huge line, huge is dead CCFL tube. line 1 pixel or so is bad LCD. there you go me pretending to see your screen. this PC is trash, it is not worth fixing for sure. try the VGA jack on the rear to a real modern 2010 or newer monitor if that works use that. till the hDD dies. next.
SOURCE: Gateway Laptop
This is either an operating system failure or hard drive failure. Start by reloading a fresh operating system (Vista) with your recovery or operating system disc. If you have any problems during or after the install, then it's the hard drive and will need to be replaced.
SOURCE: md2614U will not start. DVD drive cycles but no
Try taking the memory out and putting it back in. Also could try known good working ram.
SOURCE: Hi i have a gateway
The way to restore Gateways is to hold down the ALT Key andrepeatedly hitting f10 then it should bring you to a boot sequence screen thenchoose the HDD and then hold down ALT and repeatedly hit f10 again that shouldprompt the restore feature for gateway. If that doesn't work,the only way to doit is to boot into windows and run the Recovery program.
ALL DATA WILL BE ERASEDON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THEPOWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURINGTHIS PROCESS.
Hope this helps,
