Hi there i have a 3 thread singer industrial overlocker and im trying to find some where where i can download instruction to thread it but i aint having any luck.
would you know where i could possibly get some help from please or download the instruction manual for it
singer industrial over locker serial :460K15
thankyou
SOURCE: singer 251-2 industrial sewing machine
It was a tough find but here is your manual:
http://www.bestneedles.com/catalog/singer/Singer%20Instruction%20Manuals/251-Class-Inst.pdf
SOURCE: Threading three thread Baby Lock Overlocker EF 405
Ther should be a color coded threading chart on the front inside cover.
SOURCE: Thread Keeps snapping on my 4th reel brother 1034d overlocker
I was having the same problem. I was trying to thread only that 4th one because it keep breaking. It did not stp til I rethreaded all the threads and did it worked fine
SOURCE: Threading an Empisal Overlocker - Model S4D
All sergers thread the same way and sergers have to be threaded in a certain order. I made a jingle out of it...
upper looper
lower looper
right needle
left
It would be best to have a tweezers handy to help with the thread and threading.
always be sure the lower looper thread goes over the top of the upper looper then out the back. I would be surprised if your thread guides are not color coded.
If you look at the top thread guides or the spools. First from left to right thread the 3rd spool, then the fourth spool. Then you thread the right needle (the second spool) then the left needle (1st spool.
The lower looper can be tricky because you have to thread it from the back of the looper to the front.
Pull the threads out the back from under the foot. Then go ahead and run it slow watching to see if it starts making a chain. It should. If not do it over again.
Good luck
Rick Engel
SOURCE: I need an operating manual for an industrial
Try www.singer.com, they have manuals. Also google it. There are a lot of manuals available on the 'net, including this site.
