Washing Machines Logo
Debra Lenthe Posted on Oct 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water fills in drum but does not spin or move
Anonymous
Level 3:
  • Master 1,940 Answers
  • Posted on Oct 28, 2011
Anonymous
Master
Level 3:
Answers
1940
Questions
0
Helped
953540
Points
5951
You will have to open your Washing Machine to view the Drum Motor and Drum assembly. It sounds like your belt has broke or is worn out, or your Drum Motor is not turning. If the Drum Motor is not turning, you may have a bad Drum Motor or Motor Control Board. A trained professional should be contacted to perform these repairs if you are unsure about the repair process.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
There seems to be water trapped at the top inner drum due to water inlet pouring miss and filling where it shouldnt
The inner basket has a balance ring that is filled with liquid by design. Suspension parts are most likely causing your problem
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Started filling, made a loud noise, stopped filling immediately, door wouldn't open. I tried everything to get it to open. Running the spin cycle finally got the door open at the end of the cycle, though...
The washer drain the water if you put on spin. all electronically controlled washer won't unlock the door and or spin if there's water inside the water has to be drained out first.If the basket didn't move(no motor movement) and it finished the cycle, POSSIBLE problem is the motor control board. Motor Control Board 00436461
I have a maytag LSE7806AEE that stopped after filling the washing machine with water. I have tried everything to get it started but it will not respond.
since you can get water going, power is ok. Once water is filled, it should start automatically. Sine the drum is not moving to wash the load, it is down to drum mechanism. BTW if you manually move the knob to spin what happens?
1helpful
2answers
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
My washer fills up, but not inside the machine. If I put the machine on spin, the water drains out. Why won't it fill inside the machine?
The water is going into the machine, but somewhere below the inside drum. I can hear it sloshing around if I move the inside drum. If I put it on the spin cycle, it does not spin, but the water comes out of the hose and into the sink.
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Front Loader spinning failure
check you can turn drum by hand if rotates freely then youre motor brushes will have worn out the motor needs to be removed to fit replacements but they are cheap to replace.
Top Washing Machines Experts
john h
