Question about Parrot SA Parrot MKi9200 Advanced Color Display Bluetooth HandsFree Car Kit
When someone calls me. Both MKI9200 and my phone LG Optimus one rings. It should ring only Parrot trough car speakers. What can I do?
Posted by Karmen D. on
Daniel Boyes
    Sergeant:
  • Parrot SA Expert
  • 436 Answers
You will need to set up an in-car profile in the phone menu then change the ring option to off.
Posted on Nov 13, 2011
I have a Net10 LG Optimus L35G I dropped it in water. It worked fine for a month added new airtime and the internet and speaker went off. They were able to fix the internet but still no speaker. I cant...
Electronics and water do not mix. You can try to turn the volume up, Turn the ring volume up, Try using it with headphones or wireless headphones, Almost anything can be fixed, but at what cost? If the simple things do not get results, there is probably an internal problem, sound amplifier, speaker, switching, or control.
Most internal problems would near or exceed the cost of replacement, Sorry!
Mar 03, 2018 | Net10 LG Optimus Logic Cell Phone
I have a optimus chic lg phone, some how the speaker no longer works , phone no longer rings, no sound, how do I fix this problem
assuming its not muted by volume control or a sound app, have you tried just rebooting it? If you have then have you tried connecting it to the lg software and doing a system update. Worst case scenario will be factory reset. I doubt it's a harware failure
Jan 13, 2013 | LG E720 Optimus Chic black
No ring sound
MY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Oct 25, 2012 | Virgin Mobile - Lg Optimus Elite Mobile...
Mki9200 won't list itunes
If you don't find a solution good luck with custemer service
May 26, 2012 | Parrot Mki9200 Advanced Color Display...
How can i use my song as ringing tone
As your using lg optimus you can use song as ringing tone as simple as it just follow the step which i will tell you.If you have song in your memory card you can go to that folder and then select the song and then select option there you will get number option in that select use tone there you will get a pop up menu in that you can select as ring tone.After this you can make call from your friend mobile to your mobile there you can here your ring tone.
Jun 14, 2011 | LG Optimus 7 E900 (16 GB) Smartphone
I have a MKi9200 just updated to the latest software all went ok turned it on and just get the start screen but will not work
Hi
I have a a Parrot Mki9200, I did an update via USB and since then the whole unit hasnt turned on when the ignition is on.
Can you help?
May 14, 2011 | Parrot SA Parrot MKi9200 Advanced Color...
Ipod won't connect with parrot mki9200
make sure you have the latest software on you parrot, then reset you ipod to clear all faults.
Dec 08, 2009 | Parrot Hands-Free Car Kit with LCD Display...
Have a Mercedes W209 (CLK500) 2003 and I am trying to install a Parrot MKI9200, Parrot's sit says no adapter needed but the wiring doesn't suggest that. Can someone tell me what wire is needed please?
it depends what audio system you have. if you have the sat nav system then the radio is in the boot and you will need a special 10 speaker harness. you best bet is to find your nearest Parrot accredited installer to do the job. Try Parrot .com
Sep 13, 2009 | 2003 Mercedes-Benz CLK-Class
Parrot SA Parrot MKi9200 Advanced Color Display Bluetooth HandsFree Car Kit Logo
263 people viewed this question
Top Parrot SA Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Marvin
Marvin
Are you a Parrot SA Cell Phone Expert? Answer questions, earn points and help others
