SOURCE: Everything is displayed sideways on my monitor. how can I fix that ?
I suppose you have Nvidia Card Installed if yes then Right Click Your Desktop and select Nvidia select Standard Settings and go to Display + Rotate Display and set No Rotation . Thats it!
SOURCE: how do i open the dell flatscreen to look inside
tonytony_r, If you are really intent on opening your LCD monitor, then visit YOUTUBE and search for the longer (8-12min) video clips of LCD monitor disassembly and / or repair. BUT REMEMBER THIS!!! YOU DO SO AT YOUR OWN RISK!!! iF YOU ARE NOT VERY CAREFUL, YOU COULD DAMAGE THE LCD SCREEN BY FRACTURING (CRACKING THE GLASS) SCREEN. Have you researched the web to find out what types of failures of electronic components to look for? I'm louie12fix on fixya or lmistyrel @ aol.com Good luck.
SOURCE: I need a power cord for Dell 1503FP 15" LCD
any computer store can seel u that or i can sell u one or u can buy one from Amazon, go to the link.
http://www.amazon.com/Computer-Monitor-Power-Cable-3ft/dp/B000BSHHMK
SOURCE: the monitor display options show
Please read here: Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
http://www.fixya.com/support/r4554052-dell_monitor_lock_unlock_instruction
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Replacement board: http://www.lcdrepair.us
SOURCE: i have dell LCD monetor
Service manuals; Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
http://elektrotanya.com/?q=showresult&megnev=dell&megnev2=1503&kategoria=monitor&kat2=all
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Please leave rating if it helps.
