Computers & Internet Logo
My screen went black on my toshiba satellite C655-S5132 laptop when I turned it on after the toshiba came on. It was working fine until I tried to connect a projector to it and mashed some of the F buttons. I disconnected the projector turned it off. When I turned it back on it went from Toshiba to black with a nonflahsing cursor in left top help
Paul Woodward
    Sergeant:
  • 200 Answers
Sounds like an irq conflict after trying to install projector. you will have to boot into safemode and go grom there. dont know what op system your using . windows used to be f8 on start up but thats changed now too.
Posted on Oct 09, 2017
5 Related Answers
Anonymous
  • 113 Answers
SOURCE: Toshiba laptop- error upon start up-
I'm sorry to say that it looks like the hard drive is going or has gone bad. You can try removing it, and checking to see if it could be loose, but in virtually every case that I've seen this, the drive was dying.
If you can connect the drive to another machine as a secondary (you may need an adapter if IDE, Sata would work directly) drive, you may be able to pull some or all of your files, if the drive has not completely gone bad, and assuming where it is going bad is not where your data is stored.
The good news is that if you buy a new drive, you will need to reinstall your OS and applications, but it is likely that the machine would then work fine.
Posted on Feb 08, 2008
Anonymous
  • 117 Answers
SOURCE: Toshiba Satellite laptop w/ blank, black screen & blinking cursor
the hard drive is not checking in correctly. go into your f2 function which is your bios. see if in there during the boot options if you have a hard drive showing up. if you do, you would need to check if the hard drive has failed or the o.s. is corrupt.if you do not see a drive there, its failed, check to see if its seated correctly. if it is seated correctly the drive has failed and will need to be replaced.
if it shows up, and if you have your restore disk, load it and select repair. it will look for the hard drive and any windows installations. if it does not find any. then the drive is bad and will need to be replaced, in the event it does find the windows installation then continue to repair the machine software.
Let me know what happens when you try this
Good Luck!
Ruben
Posted on Jul 23, 2009
Anonymous
  • 1015 Answers
SOURCE: mouse pad cursor doesn't work
try using the FN key with the monitor/VGA output selection changer(usually F5). You will see a little icon that looks like two monitors. Mouse control may have been changed to the external monitor connection. See if pressing FN(function) and holding that key and then pressing the monitor key will bring back your mouse indicator. You may need to do it with the projector connected and on.
Posted on Sep 12, 2009
Azrael SRL
  • 11800 Answers
SOURCE: My Toshiba Satellite L455 is
That is the signal that Windows is missing - it's very corrupted. The only thing you can do is to reinstall it.
Posted on Oct 26, 2010
Testimonial: "thanks for the help i figured this out later and just installed linux"
Anonymous
  • 53 Answers
SOURCE: Where do I get an
You should be able to download a PDF copy of the manual here:
http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2728348/GMAD00246010_SatC640-C650_10Mar23.pdf
Hope this helps ;)
Posted on Feb 03, 2011
Toshiba satellite c655-s5132. I try to install Windows7 32 bit. Messeage comes up No device drivers were found. Make sure that the installation media contains the correct drivers
Its trying to install something and apparently cant find a driver. Easy to fix as a tech but difficult to explain how to do.
You basically need to identify what is trying to install and then obtain the correct driver for it.
Online Virus Removal and PC Help Contest
I have a Toshiba laptop model# C655-S5501 with a bad keyboard (Gator Aid!). I can't find an exact model # match through Amazon. Will the "Eathtek NEW Keyboard For TOSHIBA SATELLITE C655-S5128 C655
Check eBay. I've been working on computers for years and order ALL of my replacement keyboards through eBay. I just found 9 of them after entering your model number; about $16 with free shipping. Sarawill82 hit the nail on the head for the replacement; you tube is your friend if you're doing it yourself. If it doesn't have your exact laptop, look at other videos. It will give you an idea what you need to look for to replace the keyboard.
It beats paying a computer store a $45+ bench fee, and it will only take you about 15 minutes as a novice.
Don't try to clean it; you could cause more extensive damage than just replacing the keyboard.
Toshiba satellite c655-s5132 the laptop, charger and battery work well, but did not charge the battery
If they all work well, then the battery would charge. The most likely fault is with the battery. Try to run the laptop without the battery. If it works then replace the battery.
1helpful
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
How do I replace screen on satellite c655-s5132 with screen from satellite L305-s5919?
I'm sorry, but this isn't possible. The screens are two different sizes. The Satellite C655-S5132 has a 15.6" Widescreen display while the Satellite L305-S5919 has a 15.4" Widescreen display. The two aren't interchangeable. Sorry!
Thanks, and have a great day!
Wht version of BIOS is currently being used used on a toshiba satellite C655-S5132
@hursey_micha
The current version of the BIOS for the Toshiba C655-S5132 is v1.60. You can find more information at https://support.toshiba.com or just click here.
Cheers,
I have failed to get windows xp drivers for toshiba satellite c655-s5132
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2860972&rpn=PSC08U&modelFilter=C655-S5132&selCategory=2756709&selFamily=1073768663
Simply select Windows XP from the dropdown menu and it has all the drivers and applications Toshiba has for your laptop for XP.
3answers
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. [email protected] for any additional questions.
2answers
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Marvin
Marvin
