When the weather out side gets cold my water heater acts like there is air in the pipes. well now i have hot water in the water heater but no hot water will come out in the house. only have a small stream of water that comes out when i turn on the hot water..my cold water works fine
SOURCE: Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
SOURCE: Water heater ground
run to breaker panel or drive a 8ft ground rod and connect to it the water line is no longer acceptable as the public utility's are using pvc for gas and water now and this is no longer a practice you could use the ground rod that is already installed on your service and use connector , but something you might do well to check is to make sure in the process of installing the plastic pipes the ground going to the panel was not also disrupted if so you will need to install 2 8ft ground rods at least 6 ft apart and daisey chain together with proper size ground wire . # 4 solid for 200 amp and # 6 solid for 100 amp service , I would make sure the panel ground is solid very important for safety ,, let me know if i can further assist
SOURCE: the elbow is broken and the air from the hot water tank is leaked
Any exhaust air coming from the gas water heater is potentionally life threating. I would get it fixed. Do you have a CO2 meter close by the water heater? If it is leaking air back into the house that has CO2, after a certain amount the alarm will go off. If you dont have one get one. A must have with gas appliances.
SOURCE: Exterior mounted Rinnai tankless water heater not
What is the outside temperature? If it it is below freezing, you might have a frozen pipe. Using a plumber torch heat up the pipe, if it works, replace the insulation using a heavier layer.
Hi Faye Richardson, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
Is the cold water inlet pipe to the water heater freezing in the cold weather ?
