SOURCE: Paslode 900420 nailer green light cycles doesn't stop???
Sounds like you need a new circut assembly.
Around 40 bucks.
Thanks,
Jeff
SOURCE: How do I oil my PasLode 900420? I lost my owner's
Also make sure to put oil where the piston or hammer comes out to drive the nails in that will help keep it running smoothly
SOURCE: Brand New Paslode 900420, I bought the red gas,
Also try and check whether or not the slide where you insert the nails that you push the button down that way it is pushing the nails forward
SOURCE: Paslode IMCT Cordless Framing nailer INOP.
yes it will did you test the spark, connect the battery to the tool and push the switch does fan come on?? manually active the safety roller and pull trigger while holding the safety roller does it spark, if so the board is bad, but before replacing look for a loose connection by the trigger on the wires that push onto it. they sometimes come loose. Let me know if you need more assistance.
Testimonial: "I will give that a try--Thanks for the INFO..."
SOURCE: I just bought a paslode imct cordless framing
check for a bent driver or possibly a jammed nail in the nose area.
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
