Question about StarTech.com StarView SV211K 2-port KVM Switch
How can I find the code no. for a Eurovox tractor radio, Model No. 4115, Serial No. 359045358.3. Batach No. 5514. The previous owner could not supply
Posted by wesley alan westcott on
1 Related Answer
loftys0504
  • 191 Answers
SOURCE: Eurovox cass/radio in 2003 Massey Fergerson
on the manual you will have a slip on it with the radio code on it it will be a 4 digit no as you dissconnected the battery the radio presumes it was stolen its a safety feature
Posted on Jul 30, 2010
Model 22dc279/62 radio cd player code required in renault trafic van
Go online and search the "radio codes". Find a site that covers your brand, enter your radio make model serial number etc as required.
Pay a couple of bucks and get the code. Have you checked your owners manual, sometimes previous owners write the code in it?
Aug 21, 2014 | Cars & Trucks
I have lost the code for a eurovox 4115 audio system.
Need to remove unit and get serial number and call dealer to get code
Apr 14, 2014 | Computers & Internet
Need radio code serial no. 472001345.2.
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Nov 24, 2012 | Car Audio & Video
Hi I purchased a Citroen Berlingo 2005 second hand.Radio needs cod, I don't have. Radio is a eurovox 3385 model no.MOD3385CIT1 serial no. 46000825.4. can anyone help.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Citroen service centre and get them to enter this code for you.
Sep 23, 2012 | Car Audio & Video
My son has lost his manual for his car which had the security code for the radio cassette in it. It is a Eurovox model 4115 SN: 359046057.7. Need code after battery replacement!
if it is a stock unit the code is available from the car dealer. you will need id, registration and the serial number off the bottom of the radio.
Dec 23, 2010 | Car Audio & Video
Need a sercuity code for my eurovox car radio,model no.4115
Sorry...This Eurovox code will only be available from your Main Dealer or by using a Radio Decoding Service
Will not be available for free from anywhere on the Internet
Jul 04, 2010 | Car Audio & Video
I need the radio code for my passat
It depends on whether the code has been set by the manufacturer or a previous owner. With some radios, Eurovox for example, you need to contact them with details such as serial no. etc. and pay a fee for them to send you the code. Otherwise you could try the VW dealers to see if they can reset it.
Sep 26, 2008 | 1994 Volkswagen Passat
Car radio pin code
Hi pat... bad news I'm afraid. You need to get the code from Eurovox. There is a way to change/defeat the code, but it involves having the thing apart on the bench and actually fitting a new memory chip to the radio that does not have a code. I used to do this if someone left a unit for repair and we were not left the code. I have cut and pasted the FAQ from Eurovox's site for you, Click the link to their code request form. There are also instructions on how to enter the code
And as always, the bastards charge for the info. Sorry I couldnt actually give you a code. I used to have charge $60 to recode a radio back in the day by rechipping it.
Why is my radio not working after the battery was disconnected/replaced?
The radio requires a security code to be entered. (also known as PIN number). A security code is either 4 or 6 numbers long for most of Eurovox Units.
How can I obtain my security code?
Download the Security Code Request form located in the Downloads section. Fill it out and send it in via fax or email with proof and payment. The serial number & model number of the piece of Eurovox equipment is essential. A new security code card will then be mailed to you and your details will be registered in our database.
Why does Eurovox charge for supplying a security code?
Security and administrative reasons. We enter your details in our database so if you lose it again you only have to identify yourself and give the serial number and we will give you the security code again, we also send you a new code card.
How do I enter my security code to my Eurovox radio/cassette/CD Unit?
Refer to the owner's manual of your equipment. Turn ignition key to 'Accessories' & a number '1' or code '1' or similar will appear. Press corresponding preset buttons as you read you security code. If you have a 6 digit security code, the display will count the preset buttons pressed. i.e. display will show '1' the '2' then '3' & so on up to '6' regardless of which number is pressed. If the security code is correct, the radio will turn on. If the security code is incorrect, the display will show '2' or 'code 2' or similar. After 3 incorrect attempts, the radio will go into 'lockout mode'.
Why has my radio got horizontal lines on the display & is not responding to any buttons?
The radio has had 3 incorrect security codes entered & is now in lockout mode. For recent model radio's leave 1 hour (some radio's require ignition key to be on accessories). For older model radio's, remove power to radio by either unplugging radio or disconnecting the negative lead on the battery for 1 hour.
My radio will not accept my security code?
(1) This radio may have been replaced and now requires a different security code
(2)The security code you have been supplied is wrong.
(3)This radio has an internal fault. To check if radio works there is a temporary test code '1111' or '111111' can be used for most of Eurovox Radio. This only lasts for approx 3 minutes.
How do I enter security code to my overhead DVD/Screen combo unit?
Using the <<or>> buttons on the overhead console, scroll up or down to select the first number. Once the correct number is shown, press the ENT button. Repeat this procedure to enter the 4 digit code. As each digit is entered, it will be shown on the display.
Why does "Code Input Error" appears on my overhead DVD/Screen Combo Unit?
If incorrect codes are entered for more than 3 times, your Eurovox overhead DVD/Screen unit will show "Code Input Error" on the display.
Leave car key in the car and turn it to Accessories for approximated 1 hour, the overhead DVD/Screen unit will reset itself and shows"Security Input 1***" on the display.
Good luck... a FixYa rating would be great for my attention to your problem. Cheers mate
regards
Graeme
Mar 08, 2008 | Car Audio & Video
StarTech.com StarView SV211K 2-port KVM Switch Logo
Top StarTech.com Computers & Internet Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
