Question about Haier BC112G Wine Cooler
The temp is 25 and is stuck on LL - Haier BC112G Wine Cooler
Posted by Andy Anderson on
nexrace
    New Friend:
    Problem Solver:
  • 9 Answers
Replace the temp sensor first
$4.76 from Haier part# RF-6250-01
still stays at 25 degrees?
replace the control board & you should be done.
$26.81 from Haier part# RF-0668-04
Posted on Apr 01, 2012
My car does not warm up vary fast takes about 15 min on a warm day and on a cold day 20 to 25 min
check the thermostat for correct opening operation as it appears stuck in the open position. check the engine temperature to ensure that the fault is not in the temp gauge circuit
Jan 03, 2014 | Cars & Trucks
How to pick the right temperature rating?
This is very important so pay attention. When manufacturers tell you a bag is rated for -10 Celsius, they mean that it will keep you alive at a temperature down to -10 Celsius. They don't mean you'll be comfortable. You'll freeze but you'll survive to tell about it. For comfort, you need a sleeping bag rated about 20 Celsius to 25 Celsius colder than the expected nighttime temperature on your camping trip. For example if you are expecting zero degree nights, then buy a -20 Celsius to -25 Celsius sleeping bag.
Aug 02, 2012 | Camping, Backpacking & Hiking
Overheating,allready change the temp sensor,problem remains
When it's overheating feel the upper and lower hoses. If the upper is hot and the lower is cold you have no flow. The most likely cause would be a stuck thermostat. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jan 20, 2012 | Oldsmobile Silhouette Cars & Trucks
Haier BC-112G not working
as stated already:
  • first replace the temp sensor: $4.76 from Haier RF-6250-01
Still have the dreaded 25 degree & LL in the temp box?
  • Replace the control board: $26.81 from Haier RF-0668-04
Oct 23, 2011 | Haier BC112G Wine Cooler
Oven not staying temp needed
Hi
Thanks for using FixYa. Error F7 on your Maytag means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the touch pad/clock assembly (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 20, 2010 | Maytag 30" Self-Cleaning Freestanding...
GE Monigram Ref, main food comparment stuck at 25 degrees
is your damper door between the freezer and refrige compartments opening and closing as you adjust the temp settings,they can become stuck open by ice build up,defrost the damper door and see if it closes then
Jan 16, 2010 | Refrigerators
Car starts then shuts down as if no power
In year /model 87, code 23 was oxygen sensor stuck in full rich position. I'd be tempted to try a new one.
May 03, 2009 | 1988 Dodge Daytona
Everything in the refrigerator is freezing
The 37 degree reading you're seeing is the temp. setting, not the present actual temp. When it jumps back to 22-25 its telling you what the actual temp is inside the refrig....simply wait about 24 hours. It should then read about 37...that is, the temp you set it at 24 hours previously.
Nov 23, 2008 | GE Profile PFS22 33" Artica French Door...
Haier BC112G Wine Cooler Logo
236 people viewed this question
Top Haier Furniture Experts
Colin Stickland
Colin Stickland
Dennis Boxerman
john h
Are you a Haier Furniture Expert? Answer questions, earn points and help others
