Question about Haier BC112G Wine Cooler
Haier BC-112G not working
There is a LL in the temp box and it has gone down to 25 degrees. What do I do?
Posted by Andy Anderson on
nexrace
    New Friend:
    Problem Solver:
  • 9 Answers
As stated already:
  • first replace the temp sensor: $4.76 from Haier RF-6250-01
Still have the dreaded 25 degree & LL in the temp box?
  • Replace the control board: $26.81 from Haier RF-0668-04
Posted on Apr 01, 2012
1 Related Answer
Anonymous
SOURCE: I have a Haier 42
Replace the thermostat and/or bad control board. If you don't have electronic repair skills then it would be cheaper to go buy a new one then hire someone to repair it.
Posted on Nov 17, 2010
What does it mean when "LL" shows up in the temp light box? Also the wine fridge was very cold with condensation inside and out. We just got home from a week away and noticed a high whining sound as well.
You may have had a power surge or outage while you were gone. The temp sensor may have failed or the control board may have failed. Either way, the code means that the temp in the frig is not the temp that it is set to be.
Dec 01, 2013 | Haier BC112G Wine Cooler
I have a Haier BC112G. It is not cooling at all. Temp panel works, so I can set the thermostat up or down, but nothing happens and it just goes back to room temp after that.
Our magic chef wine cooler (mcwc50dbt) when temp is set on digital panel at 45-50 it jumps immediately back to 70 degrees constantly
Sep 25, 2013 | Haier BC112G Wine Cooler
How to replace thermostat on Haier BC-112G
First lets find out why you want to change the thermostat.
  • The 112G has a control board & temp sensor
If you are having problems try replacing the sensor first then the control board.
Link to the parts breakdown page:
http://service.haieramerica.com/Models.aspx?CID=226#
The sensor is $4.76 & the control board is $26.81.
good luck,
dan
Feb 01, 2012 | Haier BC112G Wine Cooler
The temp is 25 and is stuck on LL
replace the temp sensor first
$4.76 from Haier part# RF-6250-01
still stays at 25 degrees?
replace the control board & you should be done.
$26.81 from Haier part# RF-0668-04
Oct 23, 2011 | Haier BC112G Wine Cooler
It is hellishly hot outside these days, something close to 40. I bought a 6000 Haier at Best Buy and wanted it to lower room temperature to 25 Celsius. Vain hope: working non-stop day and night at high...
This window unit cant keep up in temps above 100 degrees farenheit its not going to happen. 28 degrees celcius is all your going to get in that heat Im in St. louis MO and its the same way
116 degrees farenheit heat index
Jul 21, 2011 | Haier HWR08XC7 Air Conditioner
NEEDED: manual for BC 112G wine cooler
Hello Ahanaples,
I understand that you are trying to locate a user manual for you Haier BC112G wine coller. I have located the manual on Haier.com the following link will take you to the page then you just have to click on the model of the unit that you have the first one at the top of the page.
http://www.haieramerica.com/en/support/modelsearch
Thank you for choosing FixYa.com
Justin Burnett
Mar 28, 2011 | Haier BC112G Wine Cooler
HELLER MOBILE AIR CONDITIONER
that's the way it should work, after you set temp to 20 degrees, display jump to the inside room temp in your case 25 or 29
Jun 10, 2009 | Haier Heating & Cooling
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
HAIER BEER REFRIDGERATOR
I have this same problem.  I have read discussions on this exact topic in several forums, and I have come across a link to a Haier Service Website.  http://service.haieramerica.com/  When you go to this site login with password "HAIER" and UserID "HAIER" and look up your model number (my model number is "HBF05EABB)".  There is a "service bulletin" which provides instruction/pictures for adjusting the thermostat.  I have not tried this yet, but I intend to later tonight.  I like my beer a little cooler than 41 degrees!  Hope this helps.
Oct 26, 2007 | Haier (HBF05EAVS) Beverage Dispenser
Haier BC112G Wine Cooler Logo
246 people viewed this question
Top Haier Furniture Experts
Colin Stickland
Colin Stickland
Dennis Boxerman
john h
Are you a Haier Furniture Expert? Answer questions, earn points and help others
