Check its speaker first. Connect an other known good speaker, after disconnecting the wires to the speaker inside, and connect it to external ones, and switch ON the set, and check whether there is good sound with external speaker/s. If OK, make sure that the internal speaker has damaged, and should be replaced. If there is distorted sound with external speakers too, check and replace damaged component/s at its audio output stage circuit. If you're sound in electronics, and if
you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic
/ Time slide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
